    Angled Push/Pull
    19 Posts 10 Posters 2.2k Views 10 Watching
    • Chris FullmerC
      But its prety speedy once you get it down. The whole video is 19 seconds, and that includes making all the doghouse shape, all in real time.
      EDIT: This is Jean's method in action.
      [flash=696,601:1inco4g9]http://www.chrisfullmer.com/forums/fix_planar.swf[/flash:1inco4g9]
      • Jean LemireJ
        Jean Lemire
        Hi Chris, hi folks.
        Thank you my friend. This video is worth a thousand pictures (or scenes).
        Best regards.
        • X
          xrok1
          actually if you make the top edge and front edge perpendicular like they will be if this is built for real, you can push\pull it to your hearts content. πŸ˜‰
          • pbacotP
            yeah, Jean's suggestion is by far the fastest way to do this.
            it might be a little more time consuming to get a set length though.. (ie pull out 14" then move it up and the actual overhang will now be longer than 14")
            It is pulled straight up, so the length of overhang is still 14" (or whatever the horizontal pull is). "Around these parts" that is how overhangs are defined (on the horizontal, just like the rafter span).
            xrok1, that's right, if one first tilts the top of the box, adds lines on the rake sides, then one can pull straight out at the correct angle. Many roofs are also made with the fascias on the vertical as in Chris's example. Dog house roofs are usually just a pc. of plywood.
            (BTW how did you make that graphic with the floating ellipse?)
            Gaieus, When I press the option key (alt) on the Mac, I get a push pull that leaves a plane at the original position. I don't see how it does as you say.
            • GaieusG
              For us, puny Windows users, the Ctrl key does that. But disregard my post: in this case it doesn't work as I tried out.
              And hm... The SU Guide doesn't say a word about this in the Mac manual but never mind; neither in the Windows manual.
              I don't know where it is (officially) documented. On the Windows, it practically works like as if you moved the face along its normal.
                Why not use the Didier Projection plug in one click! β˜€
                You have a PushPull Selected faces along their normal with a given measure πŸ˜‰
                (all that in 3 seconds from the initial object front and back facets selected and I am not Paganini πŸ’š
                Or Maybe I don't understand your problem πŸ˜’
                You have same function along any vectors if you want not the "normal" way πŸ˜‰ (left side icon of the "Normal" )
                • Jean LemireJ
                  Jean Lemire
                  Hi folks.
                  See attached SU file for more ideas.
                  Inclined roof overhang 2.skp
                    darkhelmet
                    @Chris Fullmer
                    Nice and I stand corrected - that method is easier.
                    @Pilou
                    Where do I get this Didier Projection plug in?
                    Thank you all for the great feedback!
                    • X
                      xrok1
                      try Snagit screen capture software: http://www.techsmith.com/screen-capture.asp
                        Projectionv6_zip by Didier Bur 😎
