    How do I do this?
    6 Posts 4 Posters 572 Views 4 Watching
      redinhawaii
      I have basically figured out how to load a "ruby"
      but I do not know how to deal with this kind of text, it comes in not in a folder or an icon, so I got this text.
      what to do with it?
      tt_remove_material.rb
      Version: 1.1.0
      Compatible: SketchUp 7
      Removes a given material for a selection.
      Changelog
      1.0.0 - 04.03.2009
      * Remove Material
      1.1.0 - 16.03.2009
      * Remove All Materials
      * Remove Edge Materials
      Thomas Thomassen
      thomas[at]thomthom[dot]net
      require 'sketchup.rb'
      Add some menu items to access this
      if( not file_loaded?('tt_remove_material.rb') )
      plugins_menu = UI.menu('Plugins')
      sub = plugins_menu.add_submenu('Remove Materials')
      sub.add_item('Specific From Selection') { TT_Remove_Material::remove() }
      sub.add_item('From Entire Model') { TT_Remove_Material::remove_all() }
      sub.add_item('From All Edges') { TT_Remove_Material::remove_edge_materials() }
      file_loaded('tt_remove_material.rb')
      module TT_Remove_Material
      def self.remove
      	# Variables
      	model = Sketchup.active_model
      	sel = model.selection
      	definitions = []
      	# Prompt for material to remove
      	materials = []
      	model.materials.each { |m| materials.push(m.name) }
      	materials = materials.join('|')
      	prompts = ['What material to remove?']
      	defaults = ['Enter name']
      	results = UI.inputbox(prompts, defaults, [materials], 'Remove material.')
      	if results == nil
      		return
      	else
      		material = model.materials[ results[0] ]
      	Helping_Hand.start_operation('Remove Material')
      	# Iterate entities
      	sel.each { |e|
      		if e.kind_of?(Sketchup::ComponentInstance) || e.kind_of?(Sketchup::Group)
      			parent = e.definition if e.kind_of?(Sketchup::ComponentInstance)
      			parent = e.entities.parent if e.kind_of?(Sketchup::Group)
      			next if definitions.include?(parent)
      			parent.entities.each { |ents|
      				# Remove material
      				ents.material = nil if ents.material == material
      				if ents.kind_of?(Sketchup::Face)
      					ents.back_material = nil if ents.back_material == material
      			definitions.push(parent)
      		else
      			e.material = nil if e.material == material
      			if e.kind_of?(Sketchup::Face)
      				e.back_material = nil if e.back_material == material
      	model.commit_operation
      def self.remove_all
      	# Variables
      	Helping_Hand.start_operation('Remove All Materials')
      	# Iterate entities
      	model.entities.each { |e|
      		e.material = nil
      	model.definitions.each { |d|
      		d.entities.each { |e|
      			e.material = nil
      def self.remove_edge_materials
      	# Variables
      	Helping_Hand.start_operation('Remove Edge Materials')
      	# Iterate entities
      		if e.kind_of?(Sketchup::Edge)
      			e.material = nil
      				e.material = nil
      ### HELPER METHODS ### ---------------------------------------------------
      module Helping_Hand
      	def self.start_operation(name)
      		# Make use of the SU7 speed boost with start_operation while
      		# making sure it works in SU6.
      		if Sketchup.version.split(".")[0].to_i >= 7
      			model.start_operation(name, true)
      		else
      			model.start_operation(name)
      end # module Helping_Hand
      • jeff hammondJ Offline
        jeff hammond
        sometimes the rubies come in like that when downloading (that's the actual writing)
        try right clicking on the link and choose 'download linked file'..
        you'll get a file whos icon will look like a .txt file...
        example of a ruby icon on mac
        drop that into:
        macintosh HD/library/application support/google sketchup 7/sketchup/plugins
        restart sketchup and the ruby will load
        dotdotdot
          redinhawaii
          Thanks again Guys,
          I spent most of the day trying to sort this out, 9:51pm, finally seem to have something I can send my engineer that works.
          I did not have a "download linked file" options, tried a few things, and finally out of frustration tried, once again to drag if from the downloads folder to the suggested location, I got a "not authorized to modify SU" notice or something like that...but after giving my password, it seemed to have worked.
          thanks for your insights and perspectives.
          I do hope this is not a "typical SU' situation.
          aloha
          red
            What browser do you use?
            If you end up with the pure text of a ruby, you can, from the browser, so a Save As, and save it into your plugin folder. But make note of what the file name should be.
            • mitcorbM Offline
              mitcorb
              When I download a plugin, whether .zip or .rb, while in Firefox, I right click on the target, a context menu pops up with "Save link as.." option. I default the destination to desktop so that I can distribute to both SU6 and SU7. Occasionally, I have seen where it transfers as a .php or a .txt--why? I don't know. I just dump these and retry the transfer.
                You get .php some times because the link goes to a PHP script which redirects you to the download. When that happens you have to link the link instead of Save As.
