    How do I do this?
    6 Posts 4 Posters 423 Views 4 Watching
      redinhawaii
      I have basically figured out how to load a "ruby"
      but I do not know how to deal with this kind of text, it comes in not in a folder or an icon, so I got this text.
      what to do with it?
      tt_remove_material.rb
      Version: 1.1.0
      Compatible: SketchUp 7
      Removes a given material for a selection.
      Changelog
      1.0.0 - 04.03.2009
      * Remove Material
      1.1.0 - 16.03.2009
      * Remove All Materials
      * Remove Edge Materials
      Thomas Thomassen
      thomas[at]thomthom[dot]net
      require 'sketchup.rb'
      Add some menu items to access this
      if( not file_loaded?('tt_remove_material.rb') )
      plugins_menu = UI.menu('Plugins')
      sub = plugins_menu.add_submenu('Remove Materials')
      sub.add_item('Specific From Selection') { TT_Remove_Material::remove() }
      sub.add_item('From Entire Model') { TT_Remove_Material::remove_all() }
      sub.add_item('From All Edges') { TT_Remove_Material::remove_edge_materials() }
      file_loaded('tt_remove_material.rb')
      module TT_Remove_Material
      def self.remove
      	# Variables
      	model = Sketchup.active_model
      	sel = model.selection
      	definitions = []
      	# Prompt for material to remove
      	materials = []
      	model.materials.each { |m| materials.push(m.name) }
      	materials = materials.join('|')
      	prompts = ['What material to remove?']
      	defaults = ['Enter name']
      	results = UI.inputbox(prompts, defaults, [materials], 'Remove material.')
      	if results == nil
      		return
      	else
      		material = model.materials[ results[0] ]
      	Helping_Hand.start_operation('Remove Material')
      	# Iterate entities
      	sel.each { |e|
      		if e.kind_of?(Sketchup::ComponentInstance) || e.kind_of?(Sketchup::Group)
      			parent = e.definition if e.kind_of?(Sketchup::ComponentInstance)
      			parent = e.entities.parent if e.kind_of?(Sketchup::Group)
      			next if definitions.include?(parent)
      			parent.entities.each { |ents|
      				# Remove material
      				ents.material = nil if ents.material == material
      				if ents.kind_of?(Sketchup::Face)
      					ents.back_material = nil if ents.back_material == material
      			definitions.push(parent)
      		else
      			e.material = nil if e.material == material
      			if e.kind_of?(Sketchup::Face)
      				e.back_material = nil if e.back_material == material
      	model.commit_operation
      def self.remove_all
      	# Variables
      	Helping_Hand.start_operation('Remove All Materials')
      	# Iterate entities
      	model.entities.each { |e|
      		e.material = nil
      	model.definitions.each { |d|
      		d.entities.each { |e|
      			e.material = nil
      def self.remove_edge_materials
      	# Variables
      	Helping_Hand.start_operation('Remove Edge Materials')
      	# Iterate entities
      		if e.kind_of?(Sketchup::Edge)
      			e.material = nil
      				e.material = nil
      ### HELPER METHODS ### ---------------------------------------------------
      module Helping_Hand
      	def self.start_operation(name)
      		# Make use of the SU7 speed boost with start_operation while
      		# making sure it works in SU6.
      		if Sketchup.version.split(".")[0].to_i >= 7
      			model.start_operation(name, true)
      		else
      			model.start_operation(name)
      end # module Helping_Hand
      • jeff hammondJ Offline
        sometimes the rubies come in like that when downloading (that's the actual writing)
        try right clicking on the link and choose 'download linked file'..
        you'll get a file whos icon will look like a .txt file...
        example of a ruby icon on mac
        drop that into:
        macintosh HD/library/application support/google sketchup 7/sketchup/plugins
        restart sketchup and the ruby will load
          redinhawaii
          Thanks again Guys,
          I spent most of the day trying to sort this out, 9:51pm, finally seem to have something I can send my engineer that works.
          I did not have a "download linked file" options, tried a few things, and finally out of frustration tried, once again to drag if from the downloads folder to the suggested location, I got a "not authorized to modify SU" notice or something like that...but after giving my password, it seemed to have worked.
          thanks for your insights and perspectives.
          I do hope this is not a "typical SU' situation.
          aloha
          red
            What browser do you use?
            If you end up with the pure text of a ruby, you can, from the browser, so a Save As, and save it into your plugin folder. But make note of what the file name should be.
            • mitcorbM Offline
              mitcorb
              When I download a plugin, whether .zip or .rb, while in Firefox, I right click on the target, a context menu pops up with "Save link as.." option. I default the destination to desktop so that I can distribute to both SU6 and SU7. Occasionally, I have seen where it transfers as a .php or a .txt--why? I don't know. I just dump these and retry the transfer.
                You get .php some times because the link goes to a PHP script which redirects you to the download. When that happens you have to link the link instead of Save As.
