How do I do this?
I have basically figured out how to load a "ruby"
but I do not know how to deal with this kind of text, it comes in not in a folder or an icon, so I got this text.
what to do with it?tt_remove_material.rb
Version: 1.1.0
Compatible: SketchUp 7
Removes a given material for a selection.
Changelog
1.0.0 - 04.03.2009
* Remove Material
1.1.0 - 16.03.2009
* Remove All Materials
* Remove Edge Materials
Thomas Thomassen
thomas[at]thomthom[dot]net
require 'sketchup.rb'
Add some menu items to access this
if( not file_loaded?('tt_remove_material.rb') )
plugins_menu = UI.menu('Plugins')
sub = plugins_menu.add_submenu('Remove Materials')
sub.add_item('Specific From Selection') { TT_Remove_Material::remove() }
sub.add_item('From Entire Model') { TT_Remove_Material::remove_all() }
sub.add_item('From All Edges') { TT_Remove_Material::remove_edge_materials() }
file_loaded('tt_remove_material.rb')
#-----------------------------------------------------------------------------module TT_Remove_Material
def self.remove # Variables model = Sketchup.active_model sel = model.selection definitions = [] # Prompt for material to remove materials = [] model.materials.each { |m| materials.push(m.name) } materials = materials.join('|') prompts = ['What material to remove?'] defaults = ['Enter name'] results = UI.inputbox(prompts, defaults, [materials], 'Remove material.') if results == nil return else material = model.materials[ results[0] ] end Helping_Hand.start_operation('Remove Material') # Iterate entities sel.each { |e| if e.kind_of?(Sketchup::ComponentInstance) || e.kind_of?(Sketchup::Group) parent = e.definition if e.kind_of?(Sketchup::ComponentInstance) parent = e.entities.parent if e.kind_of?(Sketchup::Group) next if definitions.include?(parent) parent.entities.each { |ents| # Remove material ents.material = nil if ents.material == material if ents.kind_of?(Sketchup::Face) ents.back_material = nil if ents.back_material == material end } definitions.push(parent) else e.material = nil if e.material == material if e.kind_of?(Sketchup::Face) e.back_material = nil if e.back_material == material end end } model.commit_operation end def self.remove_all # Variables model = Sketchup.active_model Helping_Hand.start_operation('Remove All Materials') # Iterate entities model.entities.each { |e| e.material = nil if e.kind_of?(Sketchup::Face) e.back_material = nil end } model.definitions.each { |d| d.entities.each { |e| e.material = nil if e.kind_of?(Sketchup::Face) e.back_material = nil end } } model.commit_operation end def self.remove_edge_materials # Variables model = Sketchup.active_model Helping_Hand.start_operation('Remove Edge Materials') # Iterate entities model.entities.each { |e| if e.kind_of?(Sketchup::Edge) e.material = nil end } model.definitions.each { |d| d.entities.each { |e| if e.kind_of?(Sketchup::Edge) e.material = nil end } } model.commit_operation end ### HELPER METHODS ### --------------------------------------------------- module Helping_Hand def self.start_operation(name) model = Sketchup.active_model # Make use of the SU7 speed boost with start_operation while # making sure it works in SU6. if Sketchup.version.split(".")[0].to_i >= 7 model.start_operation(name, true) else model.start_operation(name) end end end # module Helping_Handend
sometimes the rubies come in like that when downloading (that's the actual writing)
try right clicking on the link and choose 'download linked file'..
you'll get a file whos icon will look like a .txt file...
drop that into:
macintosh HD/library/application support/google sketchup 7/sketchup/pluginsrestart sketchup and the ruby will load
Thanks again Guys,
I spent most of the day trying to sort this out, 9:51pm, finally seem to have something I can send my engineer that works.
I did not have a "download linked file" options, tried a few things, and finally out of frustration tried, once again to drag if from the downloads folder to the suggested location, I got a "not authorized to modify SU" notice or something like that...but after giving my password, it seemed to have worked.
thanks for your insights and perspectives.I do hope this is not a "typical SU' situation.
aloha
red -
What browser do you use?
If you end up with the pure text of a ruby, you can, from the browser, so a Save As, and save it into your plugin folder. But make note of what the file name should be. -
When I download a plugin, whether .zip or .rb, while in Firefox, I right click on the target, a context menu pops up with "Save link as.." option. I default the destination to desktop so that I can distribute to both SU6 and SU7. Occasionally, I have seen where it transfers as a .php or a .txt--why? I don't know. I just dump these and retry the transfer.
You get .php some times because the link goes to a PHP script which redirects you to the download. When that happens you have to link the link instead of Save As.
