    Column capital
    48 Posts 6 Posters 2.9k Views 6 Watching
      Now this is definitely a question of the segmentation of curves. With more segments, your design would be much more "smooth" and similar to that of the image.
      I saw you post your question in the ruby forum (hope someone will answer - I don't have that plugin currently installed). What exactly did you try to achieve with it?
      • K Offline
        Kus
        well I wanted to make a school-boy smilie, that would fit in to the context that I need to fill... well I went with the school logo but I don't know how to make it smoother... I heard of CAD importing, but I don't know how...
        • K Offline
          Kus
          i guess that I need to import a dwg image... but how to I make a jpg file a dwg one??
          http://www.gimnazija-poljane.com/P/LogoGimp.png?pic=5
            You can either use software that "converts" raster images to vector images (Google some and find out which suites you) or use curves (arcs, beziers etc.) with higher line segments than what you are currently using when tracing around your image.
              wintopo free did this quickly - you'll see it's all 'steppy' because of the raster pixels becoming lines... You could quickly redraw over it to improve it before importing to SUp...Image of DWG convertionImage of DWG imported into SKP pushpulledDWG inside zip fileSKP with DWG imported
              • K Offline
                Kus
                great... it looks great from far... but up close you can see the "steppyness"... I am on a mac... can't find a program that can open dwg files... can some1 tell me if there is a free 1??
                  A Mac limits you a bit, but try this site http://www.lemkesoft.com/lemkesoft.html
                  If you are on a budget this site has 'free' shareware ($30/35 each) (I think with unlimited use - it's up to you to be honest) for 2d-CAD and Image manipulation - including GraphicConverter which can change virtually any raster-image into many other raster-formats and also vectorize them too... I think that CADintosh only exports as DXF [that can be used in SUp], but it can import other file formats that you can first vectorize from raster-images with GraphicConverter [like HPGL and PICT]... If you have a DWG you can always import a DWG into SUp, and if the 2d drawing is too intense with that then export it as JPG or DXF into GCon' or CADin' etc...
                  • K Offline
                    Kus
                    well I have downloaded the GraphicConverter but don't know how to change it to be able to change in SU...
                    • K Offline
                      Kus
                      No problem... I have corrected it in SU... it turned out great!!! 😍
                      • K Offline
                        Kus
                        well here is the picture I have made:
                          Open the PNG file in GraphicConverter.
                          Make/convert it into a vector format - like HPGL ?
                          Import that format file into CADintosh and edit it as desired.
                          Then export its as a DXF file which can be imported into SUp as geometry...
                            Well done !
                            • K Offline
                              Kus
                              one more thing... I am using podium and I set the reflection to 10 but I did not like it... now I cant set it to 0... why???
                                remus
                                make sure youve only got faces selected when your setting reflection (or light). Podium doesnt like it if you try and give reflection to groups.
                                  Now those birds do really look fine (to me at least).
                                  So is it your school's logo?
                                  • K Offline
                                    Kus
                                    TY... Well last week I got an F for not doing my homework at the art class... And now I am trying to get it to vanish πŸ˜„ ... That is why I will probably soon make something new and ask you how to make it better πŸ˜‰ ... And If you have some ideas plz tell πŸ˜„
                                    BTW: I fixed the problem with Podium
                                      That's a fine endeavour. Just come up with the ideas and we'll do the best giving advice.
                                      • K Offline
                                        Kus
                                        well as I have sad at first I wanted to use smilies to reefer to some quotes but soon I found out that I am no good for making them... So I have just started to make the bird in 3D to use it as a smilie... but I find it difficult because I am not an expert in making curved faces and most of all birds... Any advice??
                                        • K Offline
                                          Kus
                                          Now after 3 hours I found out that I don't really know how to do this. Did anyone try something like this once?? Does anyone have some advice??
                                          • K Offline
                                            Kus
                                            Now my teacher asked me to make a picture with about 5000x5000 pixels... I am on a free version of Podium, so I can't do this. So I ask anyone to help me and just press render. Do not change the view or shadows... don't change anything... just render... plz πŸ€“
                                            LogoGimp.skp
                                            • 2 / 3
