    Column capital
    48 Posts 6 Posters 3.2k Views 6 Watching
      @kus said:
      i guess that I need to import a dwg image... but how to I make a jpg file a dwg one??
      http://www.gimnazija-poljane.com/P/LogoGimp.png?pic=5
      wintopo free did this quickly - you'll see it's all 'steppy' because of the raster pixels becoming lines... You could quickly redraw over it to improve it before importing to SUp...Image of DWG convertionImage of DWG imported into SKP pushpulledDWG inside zip fileSKP with DWG imported
        Kus
        great... it looks great from far... but up close you can see the "steppyness"... I am on a mac... can't find a program that can open dwg files... can some1 tell me if there is a free 1??
          A Mac limits you a bit, but try this site http://www.lemkesoft.com/lemkesoft.html
          If you are on a budget this site has 'free' shareware ($30/35 each) (I think with unlimited use - it's up to you to be honest) for 2d-CAD and Image manipulation - including GraphicConverter which can change virtually any raster-image into many other raster-formats and also vectorize them too... I think that CADintosh only exports as DXF [that can be used in SUp], but it can import other file formats that you can first vectorize from raster-images with GraphicConverter [like HPGL and PICT]... If you have a DWG you can always import a DWG into SUp, and if the 2d drawing is too intense with that then export it as JPG or DXF into GCon' or CADin' etc...
            Kus
            well I have downloaded the GraphicConverter but don't know how to change it to be able to change in SU...
              Kus
              No problem... I have corrected it in SU... it turned out great!!! 😍
                Kus
                well here is the picture I have made:
                  Open the PNG file in GraphicConverter.
                  Make/convert it into a vector format - like HPGL ?
                  Import that format file into CADintosh and edit it as desired.
                  Then export its as a DXF file which can be imported into SUp as geometry...
                    Well done !
                      Kus
                      one more thing... I am using podium and I set the reflection to 10 but I did not like it... now I cant set it to 0... why???
                        remus
                        make sure youve only got faces selected when your setting reflection (or light). Podium doesnt like it if you try and give reflection to groups.
                          Now those birds do really look fine (to me at least).
                          So is it your school's logo?
                            Kus
                            TY... Well last week I got an F for not doing my homework at the art class... And now I am trying to get it to vanish πŸ˜„ ... That is why I will probably soon make something new and ask you how to make it better πŸ˜‰ ... And If you have some ideas plz tell πŸ˜„
                            BTW: I fixed the problem with Podium
                              That's a fine endeavour. Just come up with the ideas and we'll do the best giving advice.
                                Kus
                                well as I have sad at first I wanted to use smilies to reefer to some quotes but soon I found out that I am no good for making them... So I have just started to make the bird in 3D to use it as a smilie... but I find it difficult because I am not an expert in making curved faces and most of all birds... Any advice??
                                  Kus
                                  Now after 3 hours I found out that I don't really know how to do this. Did anyone try something like this once?? Does anyone have some advice??
                                    Kus
                                    Now my teacher asked me to make a picture with about 5000x5000 pixels... I am on a free version of Podium, so I can't do this. So I ask anyone to help me and just press render. Do not change the view or shadows... don't change anything... just render... plz πŸ€“
                                    LogoGimp.skp
                                      Sorry, Kus, I'd do it for you but I don't have Podium (currently not even Eval) either.
                                        sepo
                                        You can't render with that resolution. BTW there is no ground plane and you can't have shadows as such.
                                          No Podium here either...
                                          However, here's a zip file containing the SKP - updated with a nice style etc, a DXF of that file so you could try importing it into another free rendered (like Bryce 5.5 ?) and a JPG image of it that's 4500px sq and 80% quality [note that the directly attached one is only 1/10 the size!] - I think it looks OK... Remember you can also use Photoshop etc on SUp's JPG images later on to adjust what they look like and add special graphic effects etc...
                                          LogoGimp.zip
                                            Kus
                                            yea well I know that Podium can't render at 5000x5000... I meant close so something like 4076x3304... BTW... I know that the shadows can't be seen on the ground but they do effect the shadows on the model itself...
                                            PS: I need to have a white background...
                                            • 2 / 3
