    Vray- D.o.F help
    renderpluginsextensions
    7 Posts 4 Posters 2.0k Views 4 Watching
    • soloS
      solo
      I am trying to get a grip of DOF in Vray and my tests have failed miserably.
      Kwistenbiebel if you are around I could use your help as i've seen many examples of your work with vray using this feature so I'd assume you could give me some pointers.
      http://www.solos-art.com
      • K
        kwistenbiebel
        Hi Pete,
        Setting the DOF is not that easy. As I recall the DOF parameters need to be set in Feet.
        So you need to convert your file units. I never used camera DOF that much in VfSU (because of that reason).
        I got away with using the 'Depth Map' option in the Frame Buffer in many cases.
        There was an interesting thread on the Asgvis forum some time ago . I'll try to find it and post the link here...
        EDIT: Found it 😄 Look here: http://asgvis.com/index.php?option=com_smf&Itemid=90&topic=1986.0
        • K
          kwistenbiebel
          A relevant image from that thread:
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/DOF_VfSU_copy.jpg
          • thomthomT
            Inches.
            • soloS
              solo
              Mucho gracias my friend.
              • off topic *
              How is Oz?
              • K
                kwistenbiebel
                No worries (as they say here 😄 ).
                And Thomas is right (again 😄😞 inches instead of feet.
                Off Topic:
                Oz is great. We enjoy it a lot, especially the weather, the beach/nature and the people.
                Work is quite busy, so no going to beach for a short while now.
                • Z
                  zzzSPUDzzz
                  Solo,
                  Check out this youtube tutorial, it's not exactly what you were looking for but it's a good alternative way of approaching DOF.......hope this helps.....http://www.youtube.com/watch?v=fDzNJYi6Bok
                  zzzSPUzzz
