    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • G Offline
      GK65
      I had the same problem. The plugin works great when I bend a simple shape, but when I try to bend a more complex shape I get the following error code:
      Error: #<NoMethodError: undefined method all_connected' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/clf_shape_bender/clf_shape_bender.rb:364:in curve_picker'
      8/Plugins/clf_shape_bender/clf_shape_bender.rb:242:in `onLButtonUp'
      The error comes up after I select the straight line. Then when I select the curved line it goes to 15% then splat!
      I love the plugin, hope I can get it working.
      Thanks!
      GK
      • W Offline
        Wlado87
        I have a problem with Shape Bender. The object is incomplete.
        see:
        https://lh3.googleusercontent.com/Ktj4QcHhGKOlIq-17yFlo72xUWgv21Xw3LZVye8uKB7kSAU2tsbN9GncEcf1ZD7FE-trkfoGhHM
        https://lh3.googleusercontent.com/7-_KTFhou6ZBcFkIL9IrBzHLThw8V2Qq4SjItYizF-Ykbq8gf7-KPSnTT4ipdbQCLmd-x_OsxOc
        What is wrong.
        skp is in attachment.
        Untitled.skp
          What is wrong is that your original is only 1/4 of a centimeter long. Too small for SketchUp. It works perfectly if you scale it up to a reasonable size, first.
          shape bend.skp
          • W Offline
            Wlado87
            I had the same problem when I was doing with the larger size. But the problem was gone when i removed the SketchyPhysics plugin.
            I have new problem (in picture). The green grid is out of way.
            https://lh6.googleusercontent.com/af0n09oRwWEsOVhBeh-gLb30N1Lxvu2AZ7f1BuwpSW_8Dj5Bifren5mOLYiW1XWUUgc22DE5BNA
            Thanks for first answer.
            Struna1.skp
              I don't know what you mean by "out of way" but it seems to me that you would benefit from learning more about the basics of using SketchUp before you get to trying stuff like this. What you're asking SketchUp to do is create a huge number of edges and faces which is going to cause it to bog down at best. You could create this shape much more easily if you made only a single revolution of the helix and copied it enough times to make up the length you need.
              And work at a larger scale to give SketchUp half a chance to do what you want.
                Shirin2u
                I have a problem with using this plugin. Im new to sketchup, I downloaded the file and the processor but I dont know how to make it work lol anyone can help me here please?
                when I click on the file its like I cant open or install anything.
                • BurkhardB Offline
                  Burkhard
                  There are some threads here, which explains how to install Plugins. Here is one:
                  http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                  [http://www.ia-plus.de(http://www.ia-plus.de)]
                  • W Offline
                    winnersky
                    thank you
                    • H Offline
                      hlferrell
                      This tool looks incredible! I haven't gotten it to work yet, though. I have created a ramp and an arc and a line that stretches the length of the ramp - the line is on the red axis as the instructions indicate. I select the component (the ramp), then I select the shape bender tool and then try to select the single line. It doesn't seem to recognize the line - or anything once I've selected the shape bender tool.
                      Any advice would be greatly appreciated. Thanks!!
                        There are a number of things that it could be. Could you post at least a screen shot of the setup?
                        • TIGT Online
                          Also try doing it it with the Ruby Console open and post us any error messages - this might help us see what's wrong.
                          The picked line and then picked curve can't touch each other, or any other 'raw' geometry.
                          We can but hope that you have correctly extracted and then installed the tool's subfolder with all of its cursor/toolbar image files etc intact, and that you have also installed 'progressbar.rb' from Smustard.com, all as advised on the download tool's page.
                          These are the two "most popular" screw-ups ๐Ÿ˜ฎ
                            cizqa
                            Hello guys, please help me ๐Ÿ˜„
                            This is my first time using this plugin and I am having error
                            ERROR: skpHelperClasses.rb:updateSkpMaterial, curMat is nil
                            It shows continuously after I click on the Shape Bender icon, it stops when I click on the red-axis line, and it starts to show again after I click the curve. I get to the screenshot I attached, but when I click enter to finalize the bending --> bugsplat!
                            Anybody knows what's wrong? Thank you very much.
                            Siska
                            • TIGT Online
                              This is a V-ray related error and sometimes appears in other tools when it's not working properly.
                              http://forums.sketchucation.com/viewtopic.php?p=327671#p327671
                              If you disable V-ray and restart Sketchup does the error stop ?
                              Thomthom also has a script that disables V-ray's load until you need it, which also speeds up startups...
                              Also check on the latest V-ray version etc as he advises in the link above...
                                cizqa
                                I have disabled Vray from the preferences. Error message doesn't show anymore, but still, I got bugsplat whenever I try to hit Enter (finalize the bending). Thanks in advance ๐Ÿ˜„
                                  What version of SketchUp are you using? The latest SU8M3 fixed even more bugsplats.
                                  • TIGT Online
                                    Can you post the simple SKP - group/line/curve - that you are trying to use...
                                      rob-m
                                      I have the same issue. I have an object(in this case some simple 3d text). I have a curve. I have a line on the red axis.
                                      I select the object, hit the bend button, and cannot do anything else. It won't let me click a line or otherwise.
                                      With the ruby console open, I get this message repeating on mouse move or clicks:
                                      Error: #<TypeError: can't convert nil into String>
                                      I am using the free version of SU8.0.14346
                                      I get the same issue on SU7
                                      • TIGT Online
                                        Rob-m
                                        Are you sure you have installed the files/subfolder correctly, and have got/installed the separate progressbar.rb helper file as directed on the download page ?
                                        I suspect that the tool is failing because it can't find some file it needs, probably a cursor image file in the tools subfolder...
                                        This is what your file/folder 'footprint' should be...
                                        Also if it looks like this check there is no "Compatibility Files" button on the Plugins folder window - with Vista/Win7 if you don't have FULL security permissions to write to a folder the system might shunt things off into a side folder without telling you, thereby breaking the paths needed by the scripts...1.PNG2.PNG4.PNG3.PNG
                                          rob-m
                                          Thanks TIG. if progressbar.rb is not installed there is normally an error when the shape bender is started. the issue I had was putting everything in the TOOLS folder, not the PLUGINS folder.
                                          Dropped the clf_shape_bender folder and progressbar.rb into the plugins folder, retarted SU8 and all works fine now. Many thanks
                                            You should never put anything into the Tools folder.
                                            • 47
                                            • 48
                                            • 49
                                            • 50
                                            • 51
                                            • 63
                                            • 64
                                            • 49 / 64
