    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.3m Views 329 Watching
    • M
      make.GQ.china
      This is indeed a very good plug-in, thank you share.
      • S
        suzid6050
        How do you download this pluggin and make it work with sketchup 7 i have only just started using sketch up. 😞 ps i am using windows vista
        • GaieusG
          Hi Suzi,
          The plugins on this forum are generally attached to the very bottom of the first post (by the author). As for installing them; simply extract the files/folders from the archive directlyunder your C:\Program Files\Google\Google SketchUp 7\Plugins folder (this is for my XP). Make sure NOT to let Windows create a separate subfolder of all the extracted files but copy them directly above.
          When it is a single file with a simple rb extension, you just need to save it above.
          Restart SU and enjoy. (And welcome)
          • S
            suzid6050
            why wont it let me select the line even though its on the red axis? 😕 I have tried redrawing the line several times but it still wont let me select it.
            • Chris FullmerC
              Perhaps you changed the model axis? Try right clicking on the red axis line and choose "Reset" if the option is available. Then redraw the line on the new red axis.
              Chris
              PS: I just used this script in a real project for the first time. It only took me a year to actually put it to use!
              All my Plugins I've written
              • mitcorbM
                mitcorb
                You put this gift out without any personal need?
                You live up to Pilou's statement "Is beautiful that please without concept"
                EDIT
                Uh, I meant the act of giving.
                • D
                  decorarq
                  Thanks a lot Chris you are very kind to share
                  Rodolfo Prieto
                  Mexico City
                    21D
                    hi chriss, i have been using this incredible plugin for quite a while now, but i recently have been running into a small problem,
                    i am not able to bend anymore, i can start the plugin, select the straigt line, and than select the bend line, but after that the progressbar at the bottom that states how far along it's going, just hangs at 5% and dosn't bend, so i don't even get to see the preview of the bend to even start it, would you know why this is??
                    SU version: 7.1 (latest)
                    i also have your LOFT plugin and this one works fine till now, so i think it's a problem with BEND itself
                    thnx for the amazing plugins mate
                    "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                    Le Corbusier
                    • A
                      archi-sketch
                      THANK YOU VERY MUCH!!
                      • Chris FullmerC
                        Hey Rachid, I'm not sure what the problem is. It sounds like a similar bug others have experienced when they had a old version of component spray installed. Any chance you have component spray installed recently?
                        Chris
                          21D
                          @chris fullmer said:
                          ... a old version of component spray installed. Any chance you have component spray installed recently?
                          Chris
                          actualy yes, i recently installed it, because i really needed for a project, but i did not know there where another version of component spray...
                          ::edit::
                          after reading your post i went and removed CS to see if this was my problem, and yup that was it 😳
                          but is there another version of CS that does not conflict with BEND??
                          Le Corbusier
                          • Chris FullmerC
                            Yup, the newest version is located here:
                            404 Not Found
                            (forums.sketchucation.com)
                            It has a few improvements, and fixes the this bug. Specifically what it was doing was interfering with Progressbar. So any script that used progressbar is broken if you have the bad version of Component Spray installed.
                            But get the new version and it should all be working smoothly. Well, as smoothly as shape bender can work, its a bit buggy 😄
                            Chris
                            • S
                              suzid6050
                              Hi just wondering if you can help me, I have installed the shape bender several times and still getting the same problem where it wont let me select the line. I have made my box a group, click on the shape bender and then it wont let me continue. I have tryed redrawing the red line, I have reset my axis but still having no luck. Please help
                              • Chris FullmerC
                                Yeah, please set up a file with the the component, curved line and straight line so it is ready to bend, then upload it here. I'll check it out and see if I can get it to work. Then we'll see where to go from there,
                                Chris
                                • S
                                  suzid6050
                                  here is the component I am trying to curve but having no success with, hope you can help, Thanks.
                                  sketch up 2.skp
                                  • Chris FullmerC
                                    Hmm, it worked for me just fine. Select the component, start the tool. The cursor changes a little bit. Hover over the straight line until it turns blue, then click on it. Then click on the curve and it should start processing. It takes about 30 seconds to process on my computer is all.
                                    So. How far into that process can you get? Does the cursor change when you try to activate the tool?
                                    Chris
                                    • S
                                      suzid6050
                                      no it doesnt change it just says please select the line on the red axis and wont let me select the line.
                                      • Chris FullmerC
                                        Would you please open the ruby console in Window > Ruby Console.
                                        Then run shape bender. See if that window shows any errors. Please copy the entire text and past it back here. Hopefully it will be giving you some odd error that I can see and fix.
                                        Chris
                                        • S
                                          suzid6050
                                          Error: #<TypeError: cannot convert nil into String>
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in create_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in make_cursors'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:128:in activate' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in select_tool'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in call' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
                                          • TIGT
                                            It looks like you have misplaced files ?
                                            C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in `create_cursor'
                                            line_cursor_path = Sketchup.find_support_file("line_pointer.png", "Plugins/clf_shape_bender")
                                            curve_cursor_path = Sketchup.find_support_file("curve_pointer.png", "Plugins/clf_shape_bender")
                                            default_cursor_path = Sketchup.find_support_file("default_pointer.png", "Plugins/clf_shape_bender")
                                            @line_pointer = UI.create_cursor(line_cursor_path, 15, 2)### line 158 ### line_cursor_path if nil !!!
                                            Do you have these images and other files in a folder called clf_shape_bender in the Plugins folder ???Capture.PNG
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 63
                                            • 64
                                            • 17 / 64
