    Materials do not show up
    9 Posts 5 Posters 1.5k Views 5 Watching
    • A
      atomik99
      I'm having an issue with materials. When I select a material in the Materials window, then click on an object in the scene, the object changes color to something similar to the texture (for example, if I try to use "Brick_Antique" the object just becomes brown, but no bricks are visible). This happens with all materials and in all files.
      Thanks in advance! πŸ˜„
      • takesh hT
        takesh h
        I think you are in "shaded" mode.
        Go to menu, select [View]-[Face Style]-[Shaded with Textures].
        • A
          atomik99
          Just checked, it was in [Shaded with Textures] and I still only see solid color where there should be materials.
          • X
            xrok1
            go inside your group or component.
            β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
            • A
              atomik99
              I can't be positive (because I've only been using Sketchup for a couple days) but as far as I can tell, the objects are not in groups. Is there anyway I can check?
              Even when I create a brand new rectangle (for example), and try to apply a texture, it does not work.
              • takesh hT
                takesh h
                Can you upload your screen capture?
                • A
                  atomik99
                  I found the problem. For some unknown reason, I was working in an extremely huge scale. My model (in real life) would be a couple miles across, but when I measured it, it was millions of miles long! πŸ˜• lol
                  So I scaled the entire layout down, and scaled down again, and again, and I can finally see the textures now (although I will have to do some editing).
                  Question: does Sketchup work like vector programs? Meaning, can I assume that every element scaled down perfectly and kept its original proportions?
                  A huge thanks to you guys for taking the time to give your input! πŸ˜„
                  • R
                    remus
                    As long as you definetly selected everything and scaled using the corner grips it will all stay in proportion.
                    A little tip for next time: if you click the tape measure tool, measure the length of an edge and then type in how long it is meant to be SU will resize the entire model automatically.
                    • GaieusG
                      SketchUp ISa vector program so it should definitely behave as such.
                      Another tip: there are templates in SU -if you are a ne user and installed SU recently,you had to choose a template at the beginning.
                      Now keep in mind that you can always create your own templates - just modify a new file/model as you wish (this means all style settings, included components like Sang is included in some, even scenes, pre-made layers etc.) AND of course, views in the way how "big" scale you are working. A woodworker would obviously like to start a new model from much "closer" than a landscape architect for instance.
                      When you have set up everything, you can save your model in File > Save as template and then choose this new template to start SU with every time you use it at Window (Skethup on Mac) > Preferences > Templates.
                      Note that always work in "real scale" (1:1) except in very extremely small/large scales. Materials are (and new materials always should be) also "scaled" to real life.
