    [req] soften/divide geometry (by angle)
    29 Posts 7 Posters 4.6k Views 7 Watching
    • X Offline
      xrok1
      i think it would be great if one could do the exact thing that soften/smooth looks like it does but with real geometry. example a (hard) soften/smooth that asks for angle just like (soft) soften/smooth but instead of rendering smooth actually smooth divides the geometry based in angle, not the full mesh. so essentially you add more detail only where needed based on angle and smoothed to get rid of rough geometry not just to appear to get rid of it?
      Whaat, maybe this option could also be added to sub-smooth.
      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
      • X Offline
        xrok1
        does no one think this would be useful? 😕
        • Chris FullmerC Offline
          Sounds like a chamfer or bevel tool or something along those lines. Is that about right?
          All my Plugins I've written
          • X Offline
            xrok1
            i was thinking more for stuff like this:cap.jpg
            this would allow one to rough model and add detail as you go, or if you find you didn't put enough detail to begin with it will add detail only to areas that need it based on an angle just like soften/smooth but add real geometry instead of faking it for render. this way you could continue to refine these areas. i guess its a method that now some people do backwards they have detail then erase it where its not needed to clean up there model, with this approach you could keep your model clean along the way adding detail as needed.
            • jeff hammondJ Offline
              jeff hammond
              that's what i was thinking too but then after xrok's last post, i'm not so sure.. i drew this up while you two were talking so i'm going to post it anyway..
              i was thinking of a sweeter way to soften the edges.. this is probably possible to put in ruby form but whaat would probably have to do it.. it took me long enough to get the drawing to this point but i'm sure the flat spots could remain truly flat instead of divided which would help keep the poly count down..
              turn on hidden geometry and look at those corners..
              roundedge.skp
              http://homepage.mac.com/jeffhammond/.Public/scf/roundedge.jpg
              dotdotdot
              • ely862meE Offline
                ely862me
                i think i know what u want... where is a sharp line adding some more polys to give a smoother look but where the surface is almost flat adding just few polys..or am i wrong?
                Elisei (sketchupper)
                Come and See EliseiDesign
                  Yeah, something like being able to subdivide a selection, and then smooth it out a bit?
                  • X Offline
                    xrok1
                    yes but the selection of what you divide would be based on an angle not a selection. imagine a script that physically does what appears to happen when you "soften/smooth edges".
                      jeff hammond
                      just in case this isn't common knowledge already, the way to get the edges to do that with subdivide and smooth is to have offset lines from the edges (not via the SU offset tool though -- the lines need to run edge to edge)
                      [flash=500,405:1jpuaj8l]http://www.youtube-nocookie.com/v/jPRb7QhzvYs&hl=en&fs=1&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:1jpuaj8l]
                      anyone know of a better way?
                      dotdotdot
                        jeff hammond
                        does anyone really use soften/smooth like that? if i'm using soften/smooth, my goal is always to soften everthing.. i've never set it to where some lines remain visible..
                        just curious
                        [edit] unless you mean something like the eraser tool/option key in which case i will soften just a line or two.. i think if you did that with actual subdivison, there'd be some weird geometry where the round meets a sharp edge.
                        dotdotdot
                        • X Offline
                          xrok1
                          subdivide and smooth already does it but with sds it divides the whole mesh so you get smooth results but wayyy too much geometry when it only needs smoothing in a few places. what if i wanted to subdivide any edge under 30 deg. and leave the rest of the mesh undivided?
                            jeff hammond
                            that's where the weird geometry happens.. somehow the round has to meet the sharp.. here's a mockup of what i'm talking about..
                            sub1edge.skp
                            dotdotdot
                            • W Offline
                              Whaat
                              (I'm thinking about it.... 🤓 )
                              • X Offline
                                xrok1
                                hey, nice to hear from you Whaat! 😄 I was hoping you'd be around. It would be an awsome addition to an already great script if you could pull this off. it would make your must have a must, must have! 😛 even though i already have it 😆
                                • X Offline
                                  xrok1
                                  [attachment=1:kukhoxs1]<!-- ia1 -->sub1edge.skp<!-- ia1 -->[/attachment:kukhoxs1]
                                  maybe something like this could be worked out:[attachment=0:kukhoxs1]<!-- ia0 -->cap.jpg<!-- ia0 -->[/attachment:kukhoxs1]
                                  • X Offline
                                    xrok1
                                    or this:cap.jpg
                                      jeff hammond
                                      there's probably a good solution for it and it might not even matter in many cases.
                                      the thing that made me think about it was imagining doing this on a curved wall.
                                      i guess it could just round off the top some?? or you'd have a wavy wall.
                                      [edit] and really, this exact situation would be better served by normal soften/smooth... i'm just curious about how it would work.. that's all
                                      dotdotdot
                                      • X Offline
                                        xrok1
                                        in that case you might need a crease tool? or it could work like round edge, or you could just use round edge.
                                          jeff hammond
                                          i know this isn't the same as xrok's request but it seems like it would have the same underlying structure:
                                          [flash=660,525:31qmg8iy]http://www.youtube.com/v/B9u0ulHoMU4&hl=en&fs=1&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:31qmg8iy]
                                          dotdotdot
                                          • X Offline
                                            xrok1
                                            hey thats pretty sweet too, what is it? round edge by bezier?
                                            • 1 / 2
