    [Obsolete] BZ__Arc for BezierSpline 1.2
    54 Posts 31 Posters 27.5k Views 31 Watching
      @tony
      just an idea πŸ’­
      Group your existing curve
      use polyline Arc corner and redraw points over the curve
      kill the group et voilΓ  πŸ˜„
      Not sure that is you want that πŸ˜’
        Daniel S
        @tonyl said:
        one question : how do u convert polyline to polyline arc corners?
        Right click on the polyline and choose: convert to polyline arc corners.
        Daniel S
          yes maybe more speedy πŸ˜†
            tonyL
            hey guys,
            thanks for the pointer. πŸ˜„
            • H Offline
              han_seller
              thank you for your info
              • Bob JamesB Offline
                Bob James
                Alas! I've loaded BZ_Arc.rb into the BZ_Dir_12 folder and the icon files into IMAGES_standard and IMAGES_CadFather but still get only the original icons and no context command.
                Moreover, it seems that BoolTools icons have become blanks!!
                • fredo6F Offline
                  fredo6
                  Bob,
                  As you are on Mac, there maybe some specificities that have never been signaled by Mac users.
                  Just to understand more:
                  1. before you dowloaded and drop the BZ__Arc extensions, did you have a correct behavior of Bezierspline (i.e., icons, contextual menu, all extensions available), and possibly presence of the BoolTool icons?
                  2. Can you also check you do have the version 1.21 installed.
                  Fredo
                    Bob James
                    I'm on an iMac (Intel) here at home: I haven't had a chance to load it on my MacPro at work.
                    Yes, Bezierspline, icons and contextual menu worked fine and BoolTools icons were okay (The "blank" icons still "work", they just don't have the graphic face).
                    I downloaded and installed the latest 1.21 version pf BezierSpline and added the BZ_Arc and icons (I also re-installed BoolTools).
                    • fredo6F Offline
                      fredo6
                      @bob james said:
                      I loaded BZ_Dir_12 folder into Macintosh HD/Users/robertjames/Library/Application Support/Google SketchUp 7/SketchUp/Plugins and now get the full operational icon set.
                      In the past I've also had to load ProfileBuilder, Podium, Projection and SCF Power Toolbar into this directory instead of the standard location: Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Plugins
                      No effect on BoolTools: that must be some other interaction
                      I guess the choice of the correct Plugin directory on Mac must obey to some subtle laws related to the initial installation of Sketchup.
                      I hope some Mac users could clarify what are exactly the rules, because I am now lost on what is right or wrong, and, without a Mac, it's not easy to give any valuable advice.
                      Fredo
                        Bob James
                        The alternate location is true also for the new version of Layer Manager.
                        I've started a new Post to address this: "What are the rules for location of rubies on a Mac?"
                          Bob James
                          PS (added 5 Aug 2009): Turns out that BoolTools is another that must be loaded in the User folder
                            Lulu4681
                            Thank you so much i really appreciate your time and offer.
                              chango70
                              Thank you very much! Another very useful plugin.
                              • P Offline
                                plessis
                                I try to install the BZ_Arc_plugin.
                                I've download the ruby and dropped it into the
                                BZ_Dir_12 folder.
                                It works .
                                But it is impossible to download the icon-files.
                                In the attachment they are light grey and don't react.
                                What am I doing wrong ???
                                Hans
                                • 3 / 3
