    Autocad Import settings ?
    5 Posts 2 Posters 584 Views 2 Watching
    • H
      HPW
      Hello,
      Is there any options to make some Import settings to finetune the import.
      For example: To include/exclude any sort of primitives like 3DPoint, Lines etc.
      I can import my Autocad drawings properly with Blocks of 3D Faces, but get 3DPoints visible which acts as Grip-Points in autocad.
      But I do not want them in SketchUp.
      So any chance ot filter them on import?
      (Or must I delete them from the blocks in Autocad before?)
      Regards
      Hans-Peter
      • thomthomT
        The 3DPoints comes in as Contructions Points in SU, right? If so, I think you can use Edit->Delete Guides to remove all Guidelines and Construction Points from a model.
        • H
          HPW
          Thanks for the tip.
          Works as suggested.
          All guides has gone.
          Other question: My Autocad data was made in metric/mm and now I get a wrong length.
          Must I convert my Autocad to Inches before importing.
          • thomthomT
            @hpw said:
            Thanks for the tip.
            Works as suggested.
            No.
            When you import there's an Option button in your file dialog. You spesify there the units of the imported DWG.
            • H
              HPW
              Thanks again. I missed this options-button.
