    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
    • U Offline
      uxcentricdarren
      Thank you!!
      • Y Offline
        yles858026
        I have installed the plug in through the extention manager, but why Id don't see any tool bar? I have only the settings under the window menu... can anyone help?
        • fredo6F Offline
          fredo6
          LibFredo6 is just a code library shared by my plugins.
          You now need to install each plugin.
          • E Offline
            erwinz
            Hi Fredo,
            I have upgraded LibFredo6 to v13.7b and simultaneously upgraded Joint Push Pull Interactive to v4.6a. And now after re-starting the Sketchup, the Joint Push Pull toolbar appears but no response when clicking any buttons, and on the window menu > LibFreddo6 Settings...also nothing happens when clicking most of the menus - both are nothing works.
            Thank you
              @erwinz said:
              Hi Fredo,
              Your profile indicates you are using SketchUp 2015. For that version you need to be using the older legacy versions of the the extension and LibFredo6 files.
              Edit: Thank you for updating your profile.
              Did you also update to the latest version of the Sketchucation tool?
              • fredo6F Offline
                fredo6
                Could you open the Ruby console for possible error messages before you click on the command icon.
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: LibFredo6 v13.8a - 04 Feb 23
                  LibFredo6 13.8a includes:
                  • Bug fixing related to licensing of ThruPaint
                  • Support for future compatibility
                  It is strongly advised to upgrade to this version if you use ThruPaint
                  Requirements: SU2017 and above
                  See plugin home page of LibFredo6 for Download of LibFredo6.
                  Main Post of the LibFredo6 thread
                  Fredo
                    sakepaint Newcomers
                    Thank!
                      mmdkabir Newcomers
                      Dear developers or sketchUcation management,
                      We do not have paypal access from Turkey. I would like you to inform us about how to buy fredo plugins.
                        mmdkabir Newcomers
                        dear developers or sketchUcation management,
                        • fredo6F Offline
                          fredo6
                          NEW RELEASE: LibFredo6 v13.9a - 20 Feb 23
                          LibFredo6 13.9a includes:
                          • Bug fixing related to SU2023 in some circumstances
                          Fredo
                          • I Offline
                            Isarescu
                            Afterupdating to 13.9a nothing works anymore. I see the extensions in the toolbar, I can press the buttons, but nithing happens: Fredo Tools, Joint Push Pull, Fredo Scale, Curviloft, Round Corner.
                            • fredo6F Offline
                              fredo6
                              @isarescu said:
                              After updating to 13.9a nothing works anymore. I see the extensions in the toolbar, I can press the buttons, but nothing happens: Fredo Tools, Joint Push Pull, Fredo Scale, Curviloft, Round Corner.
                              Later: after activating again all the licenses, Curviloft and RoudCorner works. Fredo Tools, Curvizard, JointPushPull and FredoScale still don`t work.
                              Could you open the Ruby console to see if there are errors.
                              Normally you do not need to activate again the license when you upgrade LibFredo6.
                              • zivotinjaZ Offline
                                zivotinja
                                HI Fredo, I cannot use the sketchucation 4.3 plugin it crashes all my SK2021-23. How can I install it using the regular installation process as other plugins? I have paid for ROund Corner and your bundle ~70USD However it does not work.
                                • I Offline
                                  Isarescu
                                  "Error: #<NoMethodError: undefined method wdlg_from_key' for Traductor::Wdlg:Class> c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6webwdlg.rbe:37:in check_instance_displayed'
                                  c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:233:in invoke_quick_launcher'
                                  c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredotools/fredotools.rbe:268:in block in startup' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                                  c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1449:in block (2 levels) in build_config_commands' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1385:in block in add_command'
                                  c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:147:in invoke_quick_launcher'
                                  c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_jointpushpull/bootstrap_jointpushpull.rbe:121:in block in startup' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                                  c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6quicklauncher.rbe:42:in invoke' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:445:in invoke_quick_launcher'
                                  c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:291:in block in configure' c:/users/patrudoizero/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1469:in command_invoke'
                                    dllukac
                                    Hello
                                    I just migrated to SU 2023. I have a problem with LibFredo6. I downloaded and installed the latest release, but SketchUp keeps showing an error message:
                                    "You must install LibFredo6 to run ..."
                                    I tried to uninstall a reinstall LibFredo, reboot Sketchup, reboot the computer - but an error message pop`s up on SketchUp start.
                                    No one of the installed Fredo6 plugins are working.
                                    Thanks for your help.
                                      carpinteriaymodulosvalencia
                                      hola, gracias a todos por permitirnos con sus logros de hacer mas fácil el uso de estas herramientas para un mejor desempeño y en menor tiempo. también quisiera obtener por licencia permanente el plugins fredo scale pero no cuento con ninguna de las formas de pago que mencionan. solo hay una forma de pago con la que cuento y es por medio de la entidad o corresponsal EFECTY
                                      • P Offline
                                        PATISTAN
                                        bastant bueno
                                        • fredo6F Offline
                                          fredo6
                                          What is the message? Could you include a screenshot. Thanks
                                          • Y Offline
                                            Yago Brown Newcomers
                                            Error launching Sketchup Pro 2022. Crashes.
                                            "Curviloft: This plugin requires a LibFredo6 version greater than 124. The current version is 67"
                                            How to solve it?
                                            • 94
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 112
                                            • 113
                                            • 96 / 113
