    [Plugin Library] LibFredo6
    2.2k Posts 583 Posters 7.7m Views 585 Watching
      duykim516
      Thanks a lot for this one
      • O Offline
        olbapxpablo
        i cant extract my downloaded libfredo to my sketchup8 plugin folder i got error while doing it it said cant find a libfredo file
        i need more help
        • O Offline
          olbapxpablo
          i need more help
          i got it already
          and all of plug-ins i download is working except the curviloft, example is when i make a 2 circle with different size on both end and i do the procedure and on transition part theres no output all i can see is the to circle
          and if i use the button with the face icon my su8 turn to not responding state
          i think i follow the right steps but all i can got is error
            axelcohen12345
            Merci!
            • Z Offline
              zervasgr
              Thanks a lot! Very helpful and capable plugin!
                taiwan63
                Thanks for sharing.
                • fredo6F Offline
                  fredo6
                  NEW RELEASE: LibFredo6 3.6b - 13 Jan 11
                  This new release is mainly driven by Curviloft 1.1 (and to anticipate on some future scripts). It also includes fixes for SU8 and other evolutions for all my scripts (including support a two-phase loading for Curviloft, FredoScale, RoundCorner and Tools on Surface).
                  So it is advised to download it.
                  See main post for download.
                  Fredo
                  • P Offline
                    pankaj_tamore
                    Hi friedo06
                    first of thank u for developing such useful plugin
                    Nice work dude keep it up!I'm now exicted to learn more & more abouth Ruby script
                    take care 😎
                      tonyliu52
                      Thank you!I have downloaded the plugins.
                        arjunmax09
                        I've copied paste libfredo6 in my plugins folder...Can the following folders be safely deleted....??
                        LIBFREDO6_Dir_34
                        LIBFREDO6_Dir_35
                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                        • fredo6F Offline
                          fredo6
                          LIBFREDO6_Dir_34
                          LIBFREDO6_Dir_35
                          YES.
                          Same for the plugin folders where you can remove the older folders.
                          Fredo
                            John P
                            I must be doing something wrong here. I downloaded version 3.6 and unzipped as instructed, and sure enough, I've got the folder LIBFREDO6_Dir_36 and the file LibFredo6.rb in my \Plugins directory. But when I run Sketchup, nothing new shows up in the Window menu. Any ideas?
                              The Lib is support for other tools by Fredo!
                              Many of these are Extensions and need activating from menu Window > Preferences > Extensions......
                              • H Offline
                                hero719
                                i'm beginer. thk you! πŸ‘ πŸ‘ β˜€
                                • K Offline
                                  k2wengen
                                  thank you!!! ^^
                                  have a nice day 🀣
                                  • H Offline
                                    Hexmeister
                                    Fantastic
                                    • O Offline
                                      ohsleeper
                                      when i try to unzip this i just get 100 error messages...what am i doing wrong?
                                      • fredo6F Offline
                                        fredo6
                                        Could you indicate which kind of error you get.
                                        thanks
                                        Fredo
                                        • O Offline
                                          ohsleeper
                                          http://i1120.photobucket.com/albums/l496/ohsleeper1/libfredoerror.jpg
                                          • fredo6F Offline
                                            fredo6
                                            You just have problem of Security with Write access to the SU Plugins folder. This should be true for all plugins.
                                            You will have to sort it out first to have proper access.
                                            Fredo
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 112
                                            • 113
                                            • 11 / 113
