[Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
I am still using SU8 and have been for many years. Will not upgrade, been everything I need and more. Any way to upload SU8 compatible versions again for use?
NEW RELEASE: LibFredo6 v8.5h - 27 Aug 18
LibFredo6 8.5h reestablishes the compatibility with SU8 and SU2013, which was broken with the previous version
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
NEW RELEASE: LibFredo6 v8.6a - 06 Sep 18
LibFredo6 8.6a is dedicated to the first public version of FredoCorner
Fredo
New version of Spanish language file:
NEW RELEASE: LibFredo6 v8.6c - 08 Sep 18
LibFredo6 8.6c fixes a problem of orbiting in FredoCorner.
It also integrates an update to the Spanish translation by Oxer.
Fredo
NEW RELEASE: LibFredo6 v8.6d - 11 Sep 18
LibFredo6 8.6d includes a full French translation and fixes problems for FredoCorner 1.1c.
Fredo
NEW RELEASE: LibFredo6 v8.6e - 19 Sep 18
LibFredo6 8.6e includes a Spanish French by Oxerand fixes problems for FredoCorner 1.1d.
Fredo
NEW RELEASE: LibFredo6 v8.6f - 23 Sep 18
LibFredo6 8.6f fixes problems for FredoCorner 1.1e.
Fredo
Hi there,
Up: Sorry, probably the wrong place to post that...
With Curviloft - Loft by spline, I'm getting this when selecting the "Junction by orthogonal bezier curves" as Spline method. The modifying spline style seems to stop at the third edge. Just ask me the file or screenshots if needed.
Error: #<ArgumentError: Cannot create unit vector from zero length vector>
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:inaxes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:incompute_by_offset'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:incompute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:incompute_by_normals'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:inblock in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:ineach'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:ineach_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:inspline_profiling_construct'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:inspline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:ingeneric_junction_construct'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:injunction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:inblock in link_construct_all'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:ineach' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:inlink_construct_all'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:inlink_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:inoption_set_prop'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:inoption_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:incall'
c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:inblock in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:incall'
...You're doing amazing job!
NEW RELEASE: LibFredo6 v8.6g - 27 Sep 18
LibFredo6 8.6f fixes problems for Curviloft and includes a full Chinese translation by guanjin.
Fredo
hello , my sketchup doesnt appear anything .....
its installed libfredo but doesnt make any change :<
how should i do ? -
hello im having trouble with installing all your rubies..
my sketchup version is 2018 and in extension manager, your file all goes 'unvalid signature'
i really wonder what is problem.. of course i installed your newest version, 8.6g
plz let me know how i can fix this
thank you -
NEW RELEASE: LibFredo6 v8.6h - 15 Oct 18
LibFredo6 8.6h if for FredoCorner 1.2b (Fixes in Radius offset mode).
Fredo
my sketchup version is 2018 and in extension manager, your file all goes 'unvalid signature'Invalid Signature doesn't indicate there are any problems with the extension. It only means it hasn't been "signed" by the extensibility folks at SketchUp. It has nothing to do with the functionality of the extension.
All my plugins are duly signed and scrambled by the Extension Warehouse.
So there must be something else.
Fredo
hi Fredo6,
I have downloaded the latest version of fredo6 animator and the library. I am coming up with an issue I think. I have transitioning parts in my model, I select where my model starts transitioning from. However the origin of where my model is transitioning from keeps changing.
Is there something I would need to adjust in my model?
I very much appreciate your help! -
@lionroar41 said:
hi Fredo6,
I very much appreciate your help!It s difficult to avise without the model. Could you please post it.
Also, there is a dedicated subforum for Animator.
The best would be that you open a new thread with your problem there.
Fredo
NEW RELEASE: LibFredo6 v8.6i - 21 Oct 18
LibFredo6 8.6i is for bug fixing and FredoTools 3.3a.
Fredo
I have problems with all fredo6 plugins
Have Sketchup 18 pro, uses sketchup extension manager to install
all plugins are updated and are in the same directory.
When I press an icon, it does not respond. Do not get menu and no selections around the object.
Someone who can help me.
Register LoginAdvertisement
