[Plugin Library] LibFredo6 - v16.4b - 21 Nov 26
Thanx for replies again
i've written ENV["LOCALAPPDATA"].inspect
"C:\Users\Ali Y\xF6nder\AppData\Local" -
"C:\Users\Ali Y\xF6nder\AppData\Local"Many thanks
Then can you type the commands suggested by TIG
puts a = ENV["LOCALAPPDATA"]+"" puts a.encoding puts b = a.force_encoding("UTF-8") puts b.encodingand add this one
puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
Fredo
IMPORTANT: your profile says you use Sketchup 8. Is that correct?
Thanx fredo. I use sketchup 2017. i have to update my profile.
i've written these
puts a.encoding
puts b.encodingputs a = ENV["LOCALAPPDATA"].encode("UTF-8")
and ruby said;
puts a.encoding
Windows-1254puts b = a.force_encoding("UTF-8")
puts b.encoding
UTF-8puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
C:\Users\Ali Yönder\AppData\Localbut still my problem is not solved. maybe i have to format my pc. i do not know.
Ali,
You need to type the commands one by one.
Apparently the last one seems to work.
Could send me a private message with an email address where I can send you a modified version of LibFredo6.
To be sure, can you type separately the 3 commands below:
a = ENV["LOCALAPPDATA"].encode("UTF-8")a.encodinga.gsub(/\\/, "/")The last one should return the path with \ replaced by /
Fredo
The problem should be resolved with the new version 8.1e.
Many thanks to Ali
Fredo
NEW RELEASE: LibFredo6 v8.1e - 13 Mar 18
LibFredo6 8.1e is a maintenance release dedicated to solving (again) occasional issue on Windows when the username contains non-ascii characters.
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
After downloading and installing the latest version, I am getting these errors;
Error Loading File C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
Failed to read RBE/RBS file.
Error Loading File Fredo6_!LibFredo6.rb
Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:64:inprocess' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:71:inmodule:LibFredo6_Loader'
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in<top (required)>' Error Loading File Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in-'
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:80:in<top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire'
C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:inrequire' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:inmodule:Fredo6'
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'I have full permissions on all folders in my Sketchup Plugins folder.
After reinstalling the Lib have you restarted SketchUp 2016 ?
Yes, of course. That's when I receive the error window.
Fredo will chip in soon...
The fail to read seems to be due to a wrong installation of Sketchup, that is without a "run as an administrator" on the install exe file.
Fredo
Thanks Fredo.
That was my second thought...For the avoidance of doubt, in all newer versions of Windows the only correct way to install ANY application - including SketchUp - is as follows...
Login as your normal user account.
Close SketchUp if it is open.
Find the SketchUp installer exe file.
It's probably in your Downloads folder - if not download a new version.
Select the exe file's icon.
Right-click > Context-menu > "Run as administrator"
The process starts...
When prompted choose "Repair"
Note that if you have not yet installed SketchUp, or have recently uninstalled it - the appropriate option is "Install"...
When it completes start up Sketchup and see what happens.Very rarely the "Repair" might be insufficient, it that case run the exe as above and choose "Uninstall", then run it again and "Install"...
Installing any exe installer file in any other way will cause all kinds of unexpected and weird issues...
Never install using the 'administrator' login account.
Always install as your usual user account.
Accept the default local location that is offered - anything else might cause issues...
Never install as your usual user account by double-clicking the installer exe file's icon.
Even if you have admin powers that is NOT the same as doing it correctly - there will be subtle differences... -
Fredo
Using the install.exe in my Downloads folder, I "Ran as Admin", chose Repair, let it run but still get the errors. I shutdown SU, then using the install.exe I "Ran as Admin" and chose Uninstall, let it finish and then restarted my system. Once system restarted, I went back to the download folder, "Ran as Admin" the install.exe for a fresh install, once finished I restarted my system, opened SU and tried installing fredo6 and RoundCorner using Preferences>Extensions. Closed SU then restarted. Received the following error;
C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'Other installed Extensions load fine so I don't know what to do now.
I don't have an explanation why rbe files cannot be read in certain configurations of Sketchup.
Maybe you should uninstall Sketchup from the Windows uninstall feature (in Control Panel), and then reinstall with "run as admin".
Are the other plugins "working fine" also scrambled as rbe?
Fredo
hi fredo,
loving all your plugins, you doing a outstanding work!
all my two thumbs up (im sad, unfotunately i only have two here)!i have one question/suggestion
im using all your plugins in sketchup on my mac.
and i have no tooltips via mouseoverlay (staying still with
mouse over a tool for a few seconds).can you please add those tooltips for the mac version of your plugins.
i think tooltips help a lot for people like me, who need icons an text
for a better clarification (having a ton of plugins and icons, can confuse you a lot).… or am i wrong and the tooltips are there but i have to activate it?
(wrong setting in sketchup or on your tools).
are tooltips available on the win versions of your plugins?greetings an have a nice weekend
johnny
Following on from Fredo's last comment about uninstalling/installing...
Close SketchUp if it's open.
Try running the installer exe using "Run as administrator" - as explained previously.
When prompted choose "Uninstall"Now open the folder: C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/
The AppData path is hidden by default.
Choose to show hidden files in Folder Options, or paste the address into Windows Explorer top-bar.
Choose the "SketchUp" subfolder in that, when prompted/confirmed this will delete all files and subfolders in there - so if you keep anything in there like Materials, Components or Styles then temporarily move those folders out BEFORE doing the delete.Now re-run the installer exe as before and choose "Install"...
This will replace the Plugins folder in its entirety.
Run SketchUp and test.
Move the collection subfolders back in etc as needed.
In the SketchUp Preferences remember to check and if needed reset your folder paths to collections...Reinstall your favorite Extensions using the current RBZ files you have, or download the latest ones again... or perhaps consider using the SketchUcation Toolset's ExtensionStore³ to Auto-Install chosen ones, or install en mass from a Bundle ?
First time i hear that the tooltips don't show on Mac.
They are calculated however.
Waiting for some Mac users to say whether this is a general problem or due to your configuration.
By the way, do you have tooltips showing up with other plugins?
Fredo
hi fredo,
thnx for your answer.
for me only the tooltips of the official tools are shown.
all installed plugins have no tooltip.dunno if this is a setting thing of sketchup.
greetings
Fredo
Very good observation, the other extensions are all .rb files. I will try using Windows Uninstall.
I also tried moving all plugins to the ProgramData folder instead of the AppData folder with the following errors reported;
Error Loading File C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:64:inprocess' C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:71:inmodule:LibFredo6_Loader'
C:/ProgramData/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>' -
Do NOT move files into the ProgramData folder !
[ Unless you like a major balls-up ! ]
Use the proper folders and always ensure correct installation methods etc...The error is clearly a 'permissions issue'...
These happen after an incorrect installation of the exe file...
Register LoginAdvertisement
