    HELP - Interior Render in Vray - Too dark!
    11 Posts 3 Posters 10.9k Views 3 Watching
    • J
      joaorsmello
      Hello guys!! I hope I can get some help here...
      Well, after making a model for a university work, I tried to test some renders with vray inside sketchup! I then found a hge problem I really cant solve.
      As you can see on the picture, the render was made inside an apartment, without any artificial lights. Even with so many glass doors and windows, I couldnt get the image so be brighter that the example I am sending. I tried many things, and checked all the details I knew about that could make some difference, but none did.
      The glasses faces are all correctly oriented; the GI skylight is at 300 (tried from 3 to 300, and it doesnt seen to be any difference between 30 and 300!).
      I really wanted to get an image without any artificial ilumination, and that simulated the space as if it was like midday or something. I know I could remove the roof and there would be plenty of light, but I really wnat to avoid that because I am planing on doing details on the roof I want to show, and I also donty like the shadow results without it, that kinda show that the place received direct ilumination from above.
      So what should I do to get a brighter place, as if that was a picture as bright as a place like that can be at midday, without turning on the lights...? I know it would be brighter than the result I got.
      Please help me finding any common mistakes and making standart smart set ups that help this kind of problem!
      And thanks a lot for the time and attention!!
      Joao rsm.
      NORMAL VIEW IN Su
      RENDER - TOO DARK!
      • soloS
        solo
        Care to upload the model, I am very new at vray but may be able to solve this as I had a few similar issues recently.
        http://www.solos-art.com
        • J
          joaorsmello
          Hello again!
          As requested, here is the model!
          As a student, I use lots of models I save from the net, some from here, some from other free stuff sites. As I dont remember anymore from where I got all the stuff, I apologise if I am using something from someone here without making the right notes.
          Anyway, here it is! Any help, hint and ideas are welcome for making it less dark!
          ps. Had to do a .rar cause the file is too big. sorry for that.
          joao rsm
          for help.zip
          • soloS
            solo
            Something seems wrong with the rar file.
            ! C:\Documents and Settings\PETE\Local Settings\Temporary Internet Files\Content.IE5\0RJX12W8\for%20help[1].rar: CRC failed in for help.skp. The file is corrupt
            ! C:\Documents and Settings\PETE\Local Settings\Temporary Internet Files\Content.IE5\0RJX12W8\for%20help[1].rar: Unexpected end of archive
            • J
              joaorsmello
              having trouble uploading it!
              gonna try again now!
              sorry for that!
              joao rsm
              • J
                joaorsmello
                Here it is again. tested, and works fine.
                joao rsm
                for help 2.rar
                • GaieusG
                  I could download/open the file with no problem, Pete. I changed it to a (bit bigger however) zip file in Joao's post above - hope it helps.
                  (I can't help as I don't use Vray myself)
                  • soloS
                    solo
                    Joao
                    I reset vray to default settings, turned the sun on in SU and rendered.
                    http://img211.imageshack.us/img211/4904/testvray.jpg
                    Oh, I also made the background color white
                    • J
                      joaorsmello
                      Great Great!
                      That seams already pretty better!! I tought about turning on some kind of sun in the vray options but just couldnt find it!
                      Where did u turn it on? inside the vray options? where there?
                      thanks a lot!!
                      joao rsm
                      • soloS
                        solo
                        I turned the sun on in SU (clicked on display shadows and adjusted my time and date so that sun filtered in), then reset vray to defaults.
                        • J
                          joaorsmello
                          Oh! Just noticed that!
                          Thank ou a lot! I really didnt know the sun in Su would add any modifications in the renders in vray. Because of the setting process in vray, I even tought that the shadow and sun setups in sketch were ignored and therefore didnt pay attention to that!
                          thanks a lot for that!
                          joao rsm
