    Smooth Edge
    11 Posts 5 Posters 1.4k Views 5 Watching
    • A
      arcano
      Hi to all!
      How can I make smooth the following edges ???
      Take a look at the picture, please.
      I've tried with Sub&Smooth and RoundEdges plugins without success!
      Thank you and sorry for my poor english.
      • boofredlayB
        boofredlay
        Use your Eraser tool and hold down the Ctrl key. This will smooth the edges.
        • A
          arcano
          In this way I've erased only the sketchup "line edge" but not the shape of my solid. I need this rounded module for render. πŸ˜‰
          • jeff hammondJ
            jeff hammond
            you can use the follow-me tool. draw the roundover profile on the edge of the object.. select all the edges you'd like to round then choose the follow me tool. click on the profile shape and it will follow the edges.
            dotdotdot
            • boofredlayB
              boofredlay
              arcano, I apologize for misunderstanding your question. Jeff has your solution πŸ˜‰
              • jeff hammondJ
                jeff hammond
                here's a quick video showing what i'm talking about:
                http://homepage.mac.com/jeffhammond/.Public/scf/roundedge.mov
                dotdotdot
                • A
                  arcano
                  ok, perfect! I'll try it later.
                  If I have a closed perimeter (for example all edge of cube) where I click fo follow me tool ?
                  • J
                    Jim57
                    Take a look at the Ruby script, Bezier Round Edge. For simple rounds and bevels it automates the process and makes it much easier and quicker.
                    404 Not Found
                    (www.sketchucation.com)
                    Select all the edges you want modified. I usually reduce the number of facets to 4 (or 1 if I'm bevelling), set the size of the edging, and click. Sometimes there's a bit of cleanupβ€” if you enlarge and turn on hidden geometry you can see what's going on.
                    Another wonderful timesaving script by Fred06!
                    • jeff hammondJ
                      jeff hammond
                      for that, i'd do it like this.. it's probably considered an oddball technique to most people but i think it gives the best corners..
                      http://homepage.mac.com/jeffhammond/.Public/scf/allaround.mov
                      i didn't pay much attention to size/ratio but it is based off the shape in this thread..
                      [i used a few rubies in there -- fillet, arc:center & 2pts, and weld]
                      dotdotdot
                        Maybe like this πŸ˜‰
                        • boofredlayB
                          boofredlay
                          Pilou, you don't have to double click then deselect the face. Just click the face and then use Follow Me. The profile will follow the perimeter of the face. πŸ˜‰
                          See here for a tut I made a couple years ago:
                          http://www.sketchucation.com/forums/scf/viewtopic.php?p=4286#p4286
                          Or here on the new SketchUcation Site:
                          http://www.sketchucation.com/?p=1265
