    Sketchup compatible free or almost free 3d scanner
    extensions
    6 Posts 5 Posters 3.4k Views 5 Watching
    • G Offline
      getyourbone
      Sorry if this has been posted here before. Thought I would share the info. Quite interesting.
      I just downloaded it so I haven't had a chance to try it. Anyone have any experience with it?
      Good preview and tutorial
      http://www.youtube.com/watch?v=rUmJZx8LZY0
      Download site
      http://www.david-laserscanner.com/
        That's a cool video. That YouTube channel seems interesting as well. Nice find.
        Thanks for the link.
          Came across another DIY 3D scanner project: http://blog.makezine.com/archive/2009/03/lego_nxt_3d_scanner.html?CMP=OTC-0D6B48984890
            BTM
            Cool!
            The lego one seems a bit slow though. As for the resulting shape of the laser scanner, they should use Whaat's polyreduce plugin 😄
            • MALAISEM Offline
              MALAISE
              Hi Friends
              I've done some tests using DAVID 3D scanner.It works pretty well, but you need quite a long time before getting
              some affordable results. The most important as said in Systm sequence, is to have a really 90°angle "screen".
              Then, learning MeshLab and DAVID Scanner is not time saver!
              I get still difficulties for the "obj" files alignement and spend time to clean the scans
              Here are some files I made :
              I use an old laser red (IR Spectrometry) and a PHILIPS webcam (1.3 Mpx)
              MALAISE 😉
                l.frisken
                wow, that looks really awesome. I'm hooked now! I like projects like this. I also did one on making a whiteboard screen using a wii remote and that was also fun! 👍
                just wondering what kinds of things you can scan with this.
                I would love it if sketchup joined with videotrace! because that is so similar to scanning and yet you can have so much more control over the final model
