    Ideal Internal Field of View
    4 Posts 3 Posters 566 Views 3 Watching
    • K
      kevsterman
      What would be the ideal field of view for internals? When I model I usually have my FOV at 35deg but when you get up close you don't see an awful lot. Is 60deg a bit more like it?
      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
      • R
        remus
        Yeah, 60 degrees is a good start, the best thing to do is play around, really. Different angles will work for different interiors.
        • GaieusG
          Also with bigger angles you can perform more dramatic effects that can suit interiors quite well.
          • K
            kevsterman
            Thanks guys. 60deg seems to be looking good for what I want.
