    [REQ] Fold or Bend?
    14 Posts 5 Posters 1.7k Views 5 Watching
      I'm wondering if one of the Ruby wizards might be interested in tackling a little project. Jim did a neat little script called Unfold that is very handy for making a template or pattern from a curved piece. It's very slick for things like crest rails on chairs. What I'm looking for is sort of a reverse unfold plugin. Sometimes the template/pattern is given (flat) and the width and depth of the curve of the part. It would be nice to be able to develop the curved component from that information.
      I had thought about some modification of the Projection tools but a straight projection won't work. Would that work?
      I think there'd be more than one SketchUp user who would find this useful.
      Thanks.
      Dave
        Bend function is still missing πŸ˜’
        • Chris FullmerC Offline
          Lets think through it a little bit.
          Should it try to add any geometry so that the model bends better/smoother? Or should it be expected that the user has put in enough detail for the model to actually bend. For example, an elongated cube made up of just 6 sides will not bend because there are no bend points in it. The user would have to divide it into smaller pieces so that it could bend. Or the script could attemp to add bend points into the model (I don't know how to go about this). It seems like that would be cool to implement a way for the script subdivide objects, but I don't know exactly how that would work. But it seems like it should be do-able. Heck, subdivide and smooth does it. But it would be significantly easier if the user would divide it all up first.
          Also, how should it handle components/groups. I would guess that it would be ideal to have it make the component unique and then bend it too. But it would be easiest if it could just ignore comps/groups.
          Also, I have feeling that if that elongataed cube was off axis, SU would have a hard time fitting a box around it to use as the bend bounding box. So the easy to code answer is to have user to align the model to an axis first, then bend it.
          I have not really played with other program's bend functions. Maybe I should go through the 3dsmax bend modifier. I think it only works with the geometry as the user made it - it doesn't subdivide it for you I think.
          Anyhow, those are some initial thoughts on how it could be implemented. I'm sure it sould be started small and basic and then be improved on over time.
          Chris
          All my Plugins I've written
            Chris, I'll PM you with some details shortly.
            Dave
            • jeff hammondJ Offline
              jeff hammond
              @chris fullmer said:
              LI have not really played with other program's bend functions. Maybe I should go through the 3dsmax bend modifier. I think it only works with the geometry as the user made it - it doesn't subdivide it for you I think.
              in this thread:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17151
              you'll see an animated gif from bonzai3d showing it's bend modifier. i've exported a few shapes to sketchup from a couple of different programs (bonzai3d and cheetah3d) prior to bending them.. the unbent shapes are simple with no subdivision.. apparently, the software controls the subdivision and it's not necessary for the user to divide the shapes prior to modifying them..
              dotdotdot
                That bendy bonzai3d one was precisely the image I had in my mind while I was writing this out. The abilty of the script to subdivide is interesting and challenging. It sould be straightforward for a shape like that. But what when people try to bend large complex models. Seems tricky.
                Chris
                  Slightly different, but closer to your image is the idea of fitting shapes to a path or to other shapes. This idea keeps popping up in my mind. It would be cool to draw the straight version of your wall, then draw a path that is the shape of the curve and then have the wall matchitself up tot he curve. That would be useful too.
                  Chris
                    jeff hammond
                    Chris
                    useful indeed... i personally have an exact instance to use such a thing that is a pain to draw in sketchup.. i'm running out right now but i'll post up an example later today.
                    dotdotdot
                      Daniel S
                      Chris
                      Something like this?
                      Daniel S
                        Yeah, thats pretty much what I'd have in mind for one version of it. That was not SU, right? πŸ˜„
                        Chris
                          Chris, did you get my PM?
                            Daniel S
                            Chris
                            Not SU. It`s an option called flow... Here is an example of Flow on a Surface:
                            [flash=800,450:3v3daw0b]http://vimeo.com/moogaloop.swf?clip_id=3111916&server=vimeo.com&show_title=0&show_byline=0&show_portrait=0&color=00adef&fullscreen=1[/flash:3v3daw0b]
                            Daniel S
                              Yes DAve, I got your PM and looked at the model. The woodworking terms and ideas were over my head πŸ˜„, but the model looked good. Its given me some ideas. I don't know if bend is precisely the right word for what needs to happen in your model Dave. It seems more like a "flow" as shown in the video above. Fit existing geometry onto a warped surface. Lots of great ideas here. I'll see if I can get any simple geometry to bend, warp, transform, subdivide - ANYTHING. If I get anything working, I'll post it here.
                              Chris
                                Thanks Chris. You may be right regarding what to call it.
