    [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
    201 Posts 64 Posters 180.5k Views 65 Watching
    • Chris FullmerC Offline
      Hmm, that is not good. I'll look into it. Thanks for the notice, I'll let you know if I find anything,
      Chris
      All my Plugins I've written
        bestmate
        What a cracking tool Chris your comitment never stops amazing me Phil
        • frascatiF Offline
          frascati
          Would anyone kindly help me install this in Linux?
          I'm running Linux Mint 10 on an HP 8510W with
          Intel Core 2 Duo T7500 Processor (Santa Rosa, 2.2GHz, 4MB L2 Cache, 800MHz FSB)
          256MB NVIDIA Quadro FX 570M Workstation GPU
          15.4” WSXGA
          I installed Sketchup 7.0 with Wine installer. It's working quite well for me so far.
          I have found this ruby-script instruction on a page dedicated to Sketchup Linux users...
          bug 16511, fixed as of wine-1.1.11: To use the Ruby scripts (sketchup.google.com/download/rubyscripts.html) you'll need to convert them from DOS format to Unix format. (e.g. sudo apt-get install tofromdos; dos2unix -f parametric.rb windows.rb)
          ... but am pretty new to linux and not certain how to proceed.
            hmmm, I don't know. I am not a Linux person. Someone around here should be able to help I think thought.
            • frascatiF Offline
              frascati
              Hello Chris.
              I second every accolade in this thread. What a great tool! I read and read tutorials until I was quite certain not to embarrass myself before asking how to accomplish this. It's such a fundamental need that I was certain that I was overlooking the obvious somewhere. When I was directed to your plugin I was pretty astonished that Sketchup does not do this natively somehow. Thank you VERY much for your work.
              I asked some time back about why subsequent versions of Sketchup don't incorporate more of the most useful tools developed by users. I recall that it was said to be a 'good question'. Do you happen to know? It's not as if it would add too significantly to the size of the download.
                As a user I prefer to be able to choose myself - the plugins I find useful isn't the same as the next person.
                As a developer - SketchUp plugins often go through frequent updates, so any bundled plugin would be out of date by the time it ships.
                On the other hand - it'd be great if we could have a plugin repository where we could search, install, uninstall plugins from within SketchUp.
                • frascatiF Offline
                  frascati
                  Finally solved this, hope this helps if any other Linux users stop by here. Rather than repeat a lot I'll refer to the thread....
                  http://forums.linuxmint.com/viewtopic.php?f=90&t=69740
                  That would be VERY nice.
                  This is one thing that I'm really pleased with so far with this "fat" (by linux standards) Linux distro called Mint. There is a wealth of such repositories within the installation for navigating and installing with a minimum of fuss many many utilities. Usually when a Linux tool is discovered on the web I just have to open the "package manager" in Mint and type the name of it into search and it's already there. I just click to download and automatically install it and start using it.
                  This plugin for Sketchup has been the first real baffler for me, but it turned out to be a pretty simple fix after all. I'm finding that that's usually the case with Mint. Half a dozen hard-core linux people will give you daunting command line instructions but eventually someone will come along to tell you that the solution is actually only two clicks away.
                  • G Offline
                    gehcha
                    Just discovered your plugin and it's great! Thank you. I'm having issue with it drawing circles with a radius less than 1". Is a 1" radius the limit on size?
                      I probably did not make it smart enough to do decimals. And if I did, it probably only accepts a period as a decimal placemark - which is the US standard. So if you are typing 0,5 - you might try 0.5 - and I would recommend trying it with the 0 in front, and also without the 0. I really don't know how smart the script is going to be with that. I can dig into and look at it if you would like.
                      Chris
                        Chris
                        How are you processing the input. if you use String.to_l then it should make use of the user's locale setting.
                        Example:
                        I got comma as decimal separator, model units set to mm;
                        ` "10,5".to_l
                        0.413385826771654`
                        • jojo9J Offline
                          jojo9
                          Hi Chris,
                          whats about an 'put objects perpendicular to' option? Lets say, to put the nearest face of a group/component instance on another face, (having two parallel faces)
                          application: moving a cabinet to a wall
                            That would be an interesting plugin. I'm not sure it doesn't exist already though. Seems like there might be some script out there for moving like that. I'm not sure what it would be called though.
                            • jojo9J Offline
                              jojo9
                              Indeed, Didier Bur wrote a similar tool: Align2D. But you have to set 8 points to process objects. Best used to position/put objects on unusual angled planes. Another tool of the same author is 'Drop' but it drops only vertically.
                              A dedicated tool to place/arrange furniture would save a lot of time.
                              The slide direction could result of the relationship between group-wallface and the bounding box face determine the border line between object-wall. No dialog/input box is needed for this to work.
                              Another candy to add could be to rotate objects automatically, so that the front face of a cabinet, points always forward of the wall.
                              • gillesG Offline
                                gilles
                                Hello, I tried this tool today.
                                It works fine but I got issue with circle:
                                It doesn't draw radius under 25,4mm
                                If I set radius to 100mm it draw 76,2mm radius
                                Is there a way, code to have a component instead of a group?
                                  Hi Giles, I did a very poor making this plugin international. It does not work well with metrics AND with comma decimal separators. In the US we use a decimal separator. So 23,12 for us is written 23.12 for example.
                                  The 25.4mm limit appears to be a an inch conversion thing. 25.4mm = 1 inch. I really don't remember if I set this up to work with metrics at all. And I'm so busy I will not be able to fix it anytime soon. If you would like to tweak though, feel free.
                                  Chris
                                  • gillesG Offline
                                    gilles
                                    it must be relative to the circle construction method because there is no problem with square.
                                    • brookefoxB Offline
                                      brookefox
                                      Some helpful tipsters pointed me to this handy tool, Chris, after I inquired about one which would do quite a bit less.
                                      Thank you very much.
                                      ~ Brooke
                                        TS200010
                                        Just installed them - however, no icons on the buttons and an almost immediate Bug Splat. Lost all my work.
                                        Any assistance would be appreciated.
                                          The typical cause for the icons not showing on the buttons is incorrect installation. The Splat could have the same cause.
                                            TS200010
                                            Dave,
                                            Thanks - I am a RubyNewbe ... there were no installation instructions so I just guessed - apparantly incorrectly.
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 9 / 11
