    Undo Bug
    8 Posts 4 Posters 1.8k Views 4 Watching
    • boofredlayB
      boofredlay
      I placed a texture on a surface then decided I did not want that one. This is a standard SU texture, not a custom one. I pressed the undo shortcut on my keyboard and nothing happened. So I pressed it a couple more times; still nothing. I pressed it again and got a Bug Splat.
      • thomthomT
        What SU version?
        I just tried it with SU7 Pro (downgraded).
        Fresh file. Drew a face. Applied a SU texture. Pressed Ctrl+Z. The Texture operation was undone without any crash.
        Does this happen every time for you, on any model?
        • boofredlayB
          boofredlay
          How did you downgrade to Pro7???
          I am running the latest version: 7.0.10247
          I seem to happen if I edit the texture in any way. Once I edit it I have trouble using the undo shortcut command. If I use the back arrows it works fine (at least that I can tell so far).
          Edit: Hmmm, the file I was just using... when I closed (after everything was undone) I got a Bugsplat. All I did was X out of SU.
          • X
            xrok1
            i get bugsplats when i close just about %50 of the time. ๐Ÿ˜ข
            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
            • thomthomT
              I just did a test.
              I applied some standard material to a face. I edited the width in the SU material editor, and then applied the material to another material.
              When I then press undo it undoes the material I applied to the last face.
              If I press undo again it undo the modification I did to the width of the material. BUT, the focus is then given automatically back to the material editor and the textbox specifying the width. So if I press undo again nothing happens, because SU's main window doesn't have focus. I have to give it focus before I can proceed with undoing any more.
              But no bugsplats.
              (I installed SU7 Pro, where as the 8 hour trial ran out, so it's not downgraded to SU7 free.)
              • X
                xrok1
                i noticed that problem with the focus on the material editor as well. when i paint something then hit space to get back to selection tool i get invalid# or some message from the value boxes in the material editor or sometimes it just turns the material color black if i was editing color of a texture ๐Ÿ‘Š
                • thomthomT
                  Yea. The material windows is very annoying. It catched focus way too often. I don't know how many times I've messed up settings because I thought I used a shortcut in SU, but instead I typed in some letter into a value in the material window. (Not to mention that the cursed thing keeps popping up all the time.)
                  I've also experienced many times bugsplats when I close or minimize SU. Not constantly, but often enough.
                  • AnssiA
                    Anssi
                    The drawing window losing its focus on multiple undos has been a long-standing SU feature/bug - I have got so used to it that I cannot remember if version 3 already had it...
                    Anssi
