    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 579.6k Views 135 Watching
    • GaieusG
      @plot-paris said:
      oh, that is a really bad one, Gaieus! I am not sure if I should burst with laughter ๐Ÿคฃ , feel terribly sorry for you ๐Ÿ˜ž or just blush with embarassment, because that could just as well have happened to me ๐Ÿ˜ณ
      Well, eventually it turned out that the total HD was broken so no matter what I would've done, the repair/install wouldn't have been successful. Had to buy a new HD and reinstall everything again. ๐Ÿ˜ข
      • plot-parisP
        plot-paris
        uh, thats bad!
        actually, I still try to deny that hard discs just die after several years of intenseive use. its not pleasant, when the truth catches up with you...
        • broomstickB
          broomstick
          I just discovered that the erase function hides and smoothes edges if you use it in combination with atl ctrl an shift...
          DUH!!
          • E
            Ecuadorian
            Today I discovered that I can drag-and-drop images straight from Firefox into the SketchUp viewport. ๐Ÿ˜ฒ
            -Miguel Lescano
              ๐Ÿ‘ Tricky and speedy ๐Ÿ˜Ž
              • Chris FullmerC
                I just discovered that you can use more than one modifier key when setting up shortcut keys. example
                ctrl + shift + alt + Q
                or snything along those lines. I never reazlied that... ๐Ÿ˜ณ
                All my Plugins I've written
                • plot-parisP
                  plot-paris
                  just out of interest: what function did you assign to
                  Ctrl + Shift + Alt + Q???
                  • GaieusG
                    When I press that, it triggers an automatic poking of you on Facebook.
                    ๐Ÿคฃ
                    (I dare not try if there is anything assigned to it by default because I am rendering an animation) ๐Ÿ˜•
                    • Chris FullmerC
                      It is my auto-assinate button in SU ๐Ÿ˜„
                      I don't really have it assigned to anything. It was just an example of how complex a "shortcut" could be. I thought I was stuck to simple single modifiers. Double modifiers could greatly expand my shortcut range though!
                      • mitcorbM
                        mitcorb
                        Now, what would an "auto-assinate" button do, exactly?
                        Hee Hee!
                        • Chris FullmerC
                          I struggle...
                            A list of shortcuts ๐Ÿ’š
                              Triangulate a simple rectangle surface with the Sand box? ๐Ÿ˜ณ
                              Just draw a diagonal first! ๐Ÿ˜ฎ
                              Then apply the Sand box "Add dรฉtails" ๐Ÿ’š
                                A cool one! ๐Ÿ˜ณ
                                The Duhduh of the day! Never used! ๐Ÿ˜’
                                Thx Jeff โ˜€
                                http://forums.sketchucation.com/download/file.php?id=41868&mode=view
                                • K
                                  KXI System
                                  ๐Ÿคฃ
                                  Thing was, the people who I looked up to as pro's...
                                  Are the ones that had the most "duh!"s
                                  ๐Ÿคฃ
                                  Getting the perfect sig is hard...
                                  Google it!
                                  • GaieusG
                                    That's because only those who thinkhave genuine doh moments... ๐Ÿ˜’
                                    • ely862meE
                                      ely862me
                                      ๐Ÿ˜„
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                      • K
                                        KXI System
                                        OK, I'll share a duh moment.
                                        THE COMPONENT DIALOG BOX IS JUST A MINI 3-D WAREHOUSE WINDOW!
                                        I found out by trying to search for a component and ended up with the same search results as the first page in the 3-D warehouse.
                                        WARNING, THE FOLLOWING DUH MOMENT IS PROVEN TO DECREASE PRODUCTION BY 1000%!
                                        OK, first I found one of the antics figures off the warehouse (not through the component dialog window). Now all antic models have a link to the same youtube video, so I clicked on it and next thing you know I have youtube fully working inside sketchup! ๐Ÿ˜† I got nothing done that day...
                                        Google it!
                                        • J
                                          Jim
                                          Just learned the physical size of the SU window matters when trying to print to scale.
                                          No matter what I did I could not get my unscaled print on a single page, even though it would have easily fit on a single page. After making the SU window narrower than the height, SketchUp decided it would fit a a single sheet after all.
                                          • K
                                            KXI System
                                            Found that out the hard way, 100 prints to just get close...
                                            Google it!
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 34
                                            • 35
                                            • 9 / 35
