    Vray net render
    renderpluginsextensions
    14 Posts 5 Posters 5.3k Views 5 Watching
    • O Offline
      ozzidora
      I've Vray with sketchup6, and net render seems not to
      work: IP address all correct, a pc "sees" the others, Vray
      recons the other...but nothing: the spawner on the other pc (2) stays still as a concrete block! (Windows xp professional servicepack 2 on every pc)
      can a holy soul help me?
      thx
        Can you post the content of the render log? Might be some clues there.
          ScottPara
          Are all machines on a wire and not wireless. I have found that the data transfer through wireless takes to long and the slaves stall and never connect. Just an idea but the render log that thom requested will help too.
          Scott
          Love the fact that some HATE my avatar.....
          • broomstickB Offline
            broomstick
            Also, be sure that the textures used in the model belong to a folder that is shared over the network, otherwise the slave machine will render only the diffuse color, giving you strange result.
            And I second the suggestion of wired links, wireless won't work!
            • O Offline
              ozzidora
              Thank you,
              the machines are all wired, the textures folders are shared, here the render log I use:
                That's the Render Options.
                The Render Log is what you get in this window:
                If you could copy the content of that window, paste it into Notepad and upload the file here it'd help in determining what's going on.
                • O Offline
                  ozzidora
                  thanks, I'll do this way.
                  • O Offline
                    ozzidora
                    here the log file, translation included (!)
                    • soloS Offline
                      solo
                      looks like a firewall issue on the other machine.
                      http://www.solos-art.com
                        Yes, make sure that the DRSpawner.exe is allowed through your firewall and the traffic though your network isn't blocked. Temporary disable your firewall to see if it works then.
                        • O Offline
                          ozzidora
                          windows firewall shares the spawner (it allows DRSpawner).
                          I'm "freaking out", I'll reinstall the spawner...
                          • O Offline
                            ozzidora
                            The installation of The DRSpawner on a computer needs to be made in a particular way?
                              ScottPara
                              It should not need to be installed in any special way. I am guessing it is a firewall issue or a SLOW machine that can not process the data all that well.
                              Just my 2 cents
                              Scott
                              • O Offline
                                ozzidora
                                I've forgotten to say that somitimes, months ago,
                                everything worked. The machine are not slow (2gb ram , dual core etc)
