    New API doc - typos and questions
    370 Posts 35 Posters 290.9k Views 35 Watching
      Jim
      @thomthom said:
      Wish we had red pens to scribble on the docs. πŸ˜„
      Great idea, really. I'm sure there are browser plugins that allow social sharing of sticky notes, or comments on web pages.
        Oh, yea... at least for Firefox. I mean to remember something like that.
          Could this be something? https://addons.mozilla.org/en-US/firefox/addon/2792
          Anyone tried it? Or got better solutions?
          • Chris FullmerC Offline
            Point3d.project_to_plane:
            http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#project_to_line
            Shows the wrong example code (uses from project to line). and I know I gave the link for project_to_line. Its so you can see both methods simultaneously and see the error better. Thanks!
            Chris
            All my Plugins I've written
              So far I am really truly enjoying the new docs. They feel much better, thanks for the efforts to get them to where they are. I'm also excited that changes might be able to happen faster now too, that is great.
              I'm noticing that sometimes in the methods list, when I click on a method, it takes me to the class index for that method. Other times it willtake me directly to the entry for that method within the class. I prefer the latter. But I don't know why sometimes it does one thing and sometimes it does another,
              Chris
                Error 404 (Not Found)!!1
                (code.google.com)
                It doesn't mention how to allow drop-down options by using a third array with strings separating each option with a pipe | character.
                  You can do a dropdown box?
                    UI.inputbox ['Hello'], ['World'], ['Mars|Pluto|World|Monkeys'], 'Title'
                    "Global Material Changer" and "Component Spray" uses it. That's the only way I knew it was possible.
                      Jim
                      Sure, and I made this to ease the pain a little: http://sketchuptips.blogspot.com/2008/03/inputbox-class.html
                        Nice one Jim.
                          http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#z=
                          It says:
                          Point3d.z=
                              The y= method is used to set the z value of a 3D point.
                          That second line should say "The z= method..."
                            (code.google.com)
                            Face.area actually takes an optional argument. I'm not sure what the argument is. It accepts pure numbers which then seems to be a scale factor. But it also accepts Transformation objects.
                              Same applies to Edge.length
                                The example uses project_to_line
                                 plane = [Geom;;Point3d.new(0,0,0), Geom;;Vector3d.new(0,0,1)]
                                 point = Geom;;Point3d.new 10,10,10
                                 projected_point = point.project_to_line line
                                  Tool - onMouseMove example has a bad local variable.
                                  http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onMouseMove
                                   def onMouseMove(flags, x, y, view)
                                     puts "onMouseMove; flags = " + key.to_s
                                     puts "                 x = " + x.to_s
                                     puts "                 y = " + y.to_s
                                     puts "              view = " + view.to_s
                                  The variable "key" should be replaced with "flag" I think. That makes the example work.
                                  Chris
                                    http://code.google.com/apis/sketchup/docs/ourdoc/face.html#get_UVHelper
                                    The code example:
                                     model = Sketchup.active_model
                                     entities = model.active_entities
                                     pts = []
                                     pts[0] = [0, 0, 0]
                                     pts[1] = [9, 0, 0]
                                     pts[2] = [9, 9, 0]
                                     pts[3] = [0, 9, 0]
                                     # Add the face to the entities in the model
                                     face = entities.add_face pts
                                     tw = Sketchup;;TextureWriter.new
                                     uvHelp = face.get_UVHelper true, true, tw
                                    This will return the error:
                                    Error: #<TypeError: (eval):95:in `get_UVHelper': wrong argument type (expected Sketchup::TextureWriter)>
                                    (eval):95
                                    Instead of tw = Sketchup::TextureWriter.new, the method tw = Sketchup.create_texture_writer will work.
                                    Which leads to another questions: why can't tw = Sketchup::TextureWriter.new be used as in the example?
                                      ModelObserver.onPlaceComponent
                                      http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onPlaceComponent
                                      The manual claims that a Model is passed on as the argument, but instead it's the ComponentInstance. I have not tested the rest of the ModelObserver events to see if they also match.
                                      onPlaceComponent FIXED
                                      • scottliningerS Offline
                                        scottlininger
                                        Thomas, you rock.
                                        I'll double check all of the modelobserver arguments. Thanks!
                                        • Scott Lininger
                                          SketchUp Software Engineer
                                          Have you visited the Ruby API Docs?
                                          remus
                                          For Point3d.distance_to_line the docs give the same example as point3d.distance.
                                            I can't get the DefinitionObserver to trigger at all. http://code.google.com/apis/sketchup/docs/ourdoc/definitionobserver.html Neither the onComponentInstanceAdded or onComponentInstanceRemoved events. Are these the correct event names?
                                            • 18
                                            • 19
                                            • 2 / 19
