    New API doc - typos and questions
    370 Posts 35 Posters 310.8k Views 35 Watching
      UI.inputbox ['Hello'], ['World'], ['Mars|Pluto|World|Monkeys'], 'Title'
      "Global Material Changer" and "Component Spray" uses it. That's the only way I knew it was possible.
        Jim
        @chris fullmer said:
        You can do a dropdown box?
        Sure, and I made this to ease the pain a little: http://sketchuptips.blogspot.com/2008/03/inputbox-class.html
          Nice one Jim.
          • Chris FullmerC Offline
            http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#z=
            It says:
            Point3d.z=
                The y= method is used to set the z value of a 3D point.
            That second line should say "The z= method..."
              Error 404 (Not Found)!!1
              (code.google.com)
              Face.area actually takes an optional argument. I'm not sure what the argument is. It accepts pure numbers which then seems to be a scale factor. But it also accepts Transformation objects.
                Same applies to Edge.length
                  Point3d.project_to_plane
                  The example uses project_to_line
                   plane = [Geom;;Point3d.new(0,0,0), Geom;;Vector3d.new(0,0,1)]
                   point = Geom;;Point3d.new 10,10,10
                   projected_point = point.project_to_line line
                    Tool - onMouseMove example has a bad local variable.
                    http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onMouseMove
                     def onMouseMove(flags, x, y, view)
                       puts "onMouseMove; flags = " + key.to_s
                       puts "                 x = " + x.to_s
                       puts "                 y = " + y.to_s
                       puts "              view = " + view.to_s
                    The variable "key" should be replaced with "flag" I think. That makes the example work.
                      http://code.google.com/apis/sketchup/docs/ourdoc/face.html#get_UVHelper
                      The code example:
                       model = Sketchup.active_model
                       entities = model.active_entities
                       pts = []
                       pts[0] = [0, 0, 0]
                       pts[1] = [9, 0, 0]
                       pts[2] = [9, 9, 0]
                       pts[3] = [0, 9, 0]
                       # Add the face to the entities in the model
                       face = entities.add_face pts
                       tw = Sketchup;;TextureWriter.new
                       uvHelp = face.get_UVHelper true, true, tw
                      This will return the error:
                      Error: #<TypeError: (eval):95:in `get_UVHelper': wrong argument type (expected Sketchup::TextureWriter)>
                      (eval):95
                      Instead of tw = Sketchup::TextureWriter.new, the method tw = Sketchup.create_texture_writer will work.
                      Which leads to another questions: why can't tw = Sketchup::TextureWriter.new be used as in the example?
                        ModelObserver.onPlaceComponent
                        http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onPlaceComponent
                        The manual claims that a Model is passed on as the argument, but instead it's the ComponentInstance. I have not tested the rest of the ModelObserver events to see if they also match.
                        onPlaceComponent FIXED
                        • scottliningerS Offline
                          scottlininger
                          Thomas, you rock.
                          I'll double check all of the modelobserver arguments. Thanks!
                          • Scott Lininger
                            SketchUp Software Engineer
                            Have you visited the Ruby API Docs?
                            remus
                            For Point3d.distance_to_line the docs give the same example as point3d.distance.
                              I can't get the DefinitionObserver to trigger at all. http://code.google.com/apis/sketchup/docs/ourdoc/definitionobserver.html Neither the onComponentInstanceAdded or onComponentInstanceRemoved events. Are these the correct event names?
                                scottlininger
                                I just had a big one reported to me... posting it here so folks are aware until the next fix.
                                The face.material method is entirely missing from the new docs.
                                • Scott Lininger
                                  scottlininger
                                  There's a new update live that fixes (most of) the problems reported above. There were one or two that will require me to pound on it a bit more. Keep 'em coming!
                                  I also posted a new tutorial on reading attributes.
                                  • Scott Lininger
                                    Nice one Scott.
                                    I seem to have come across three observer events that doesn't work. It would probably be useful to mark these in the docs with a warning so that people won't waste a whole lot of time trying to get them work work. ..like I have...
                                    DefinitionObserver http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17631 (Completely busted)
                                    EntitiesObserver.onContentsModified http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17970 (Add and Remove event works though. Haven't tried the Erase event.)
                                      scottlininger
                                      I also just got this one from a coworker:
                                      Sketchup.get_resource_path example fails. Looks like there's a required parameter that's not properly documented.
                                      -Scott
                                      • Scott Lininger
                                        These failing observers is quite severe. I don't suppose there's a chance the dev team can push out an update outside the servicepack schedule? (I don't know what your schedule is, but seeing that we just got an servicepack I'm a bit pessimistic to when this might be addressed...)
                                          remus
                                          A semi related typo:
                                          in this tutorial pt4=[0,9,9] whereas it should be [0,9,0].
                                            ::OFF TOPIC::
                                            All right Remus, come clean. Your always in the Ruby forum, you spotted a typo in tutorial, you answer questions once in a while....how much ruby do you know? Are you making plugins and selling them overseas for big money or something?
                                            • 18
                                            • 19
                                            • 2 / 19
