    New API doc - typos and questions
    370 Posts 35 Posters 310.7k Views 35 Watching
      Thanks Scott.
      I'm still puzzled about the six arguments for Vector3d.linear_combination.
      vec = Geom;;Vector3d.linear_combination(x, xaxis, y, yaxis, z, zaxis)
      How does this really work?
      • Chris FullmerC Offline
        Not to mention that the example at the bottom of the method does not actually include the method of linear combination. It only shows:
         vector1 = Geom;;Vector3d.new 1,0,0
         vector2 = Geom;;Vector3d.new 0,1,0
          PolygonMesh.add_polygon
          The example shows how to use the add_point method.
            Wish we had red pens to scribble on the docs. πŸ˜„
              Jim
              Great idea, really. I'm sure there are browser plugins that allow social sharing of sticky notes, or comments on web pages.
                Oh, yea... at least for Firefox. I mean to remember something like that.
                  Could this be something? https://addons.mozilla.org/en-US/firefox/addon/2792
                  Anyone tried it? Or got better solutions?
                    Point3d.project_to_plane:
                    http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#project_to_line
                    Shows the wrong example code (uses from project to line). and I know I gave the link for project_to_line. Its so you can see both methods simultaneously and see the error better. Thanks!
                      So far I am really truly enjoying the new docs. They feel much better, thanks for the efforts to get them to where they are. I'm also excited that changes might be able to happen faster now too, that is great.
                      I'm noticing that sometimes in the methods list, when I click on a method, it takes me to the class index for that method. Other times it willtake me directly to the entry for that method within the class. I prefer the latter. But I don't know why sometimes it does one thing and sometimes it does another,
                        Error 404 (Not Found)!!1
                        (code.google.com)
                        It doesn't mention how to allow drop-down options by using a third array with strings separating each option with a pipe | character.
                          You can do a dropdown box?
                            UI.inputbox ['Hello'], ['World'], ['Mars|Pluto|World|Monkeys'], 'Title'
                            "Global Material Changer" and "Component Spray" uses it. That's the only way I knew it was possible.
                              Jim
                              Sure, and I made this to ease the pain a little: http://sketchuptips.blogspot.com/2008/03/inputbox-class.html
                                Nice one Jim.
                                  http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#z=
                                  It says:
                                  Point3d.z=
                                      The y= method is used to set the z value of a 3D point.
                                  That second line should say "The z= method..."
                                    (code.google.com)
                                    Face.area actually takes an optional argument. I'm not sure what the argument is. It accepts pure numbers which then seems to be a scale factor. But it also accepts Transformation objects.
                                      Same applies to Edge.length
                                        The example uses project_to_line
                                         plane = [Geom;;Point3d.new(0,0,0), Geom;;Vector3d.new(0,0,1)]
                                         point = Geom;;Point3d.new 10,10,10
                                         projected_point = point.project_to_line line
                                          Tool - onMouseMove example has a bad local variable.
                                          http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onMouseMove
                                           def onMouseMove(flags, x, y, view)
                                             puts "onMouseMove; flags = " + key.to_s
                                             puts "                 x = " + x.to_s
                                             puts "                 y = " + y.to_s
                                             puts "              view = " + view.to_s
                                          The variable "key" should be replaced with "flag" I think. That makes the example work.
                                            http://code.google.com/apis/sketchup/docs/ourdoc/face.html#get_UVHelper
                                            The code example:
                                             model = Sketchup.active_model
                                             entities = model.active_entities
                                             pts = []
                                             pts[0] = [0, 0, 0]
                                             pts[1] = [9, 0, 0]
                                             pts[2] = [9, 9, 0]
                                             pts[3] = [0, 9, 0]
                                             # Add the face to the entities in the model
                                             face = entities.add_face pts
                                             tw = Sketchup;;TextureWriter.new
                                             uvHelp = face.get_UVHelper true, true, tw
                                            This will return the error:
                                            Error: #<TypeError: (eval):95:in `get_UVHelper': wrong argument type (expected Sketchup::TextureWriter)>
                                            (eval):95
                                            Instead of tw = Sketchup::TextureWriter.new, the method tw = Sketchup.create_texture_writer will work.
                                            Which leads to another questions: why can't tw = Sketchup::TextureWriter.new be used as in the example?
                                            • 18
                                            • 19
                                            • 2 / 19
