    New API doc - typos and questions
    370 Posts 35 Posters 311.5k Views 35 Watching
      Under the UI Classes section:
      Tool, Toolbar and Webdialog all links to the Array class: http://code.google.com/apis/sketchup/docs/ourdoc/array.html
      • scottliningerS Offline
        scottlininger
        A bunch of fixes got pushed on Friday. Thanks again to folks who found typos, both from this thread and from the wiki documentation. Keep 'em coming!
        I'm on vacation for the next week, so don't think I'm ignoring anyone if I don't reply for a few days. Thanks, guys!
        • Scott Lininger
          SketchUp Software Engineer
          Have you visited the Ruby API Docs?
          Thanks Scott.
          I'm still puzzled about the six arguments for Vector3d.linear_combination.
          vec = Geom;;Vector3d.linear_combination(x, xaxis, y, yaxis, z, zaxis)
          How does this really work?
          • Chris FullmerC Offline
            Not to mention that the example at the bottom of the method does not actually include the method of linear combination. It only shows:
             vector1 = Geom;;Vector3d.new 1,0,0
             vector2 = Geom;;Vector3d.new 0,1,0
              PolygonMesh.add_polygon
              The example shows how to use the add_point method.
                Wish we had red pens to scribble on the docs. πŸ˜„
                  Jim
                  Great idea, really. I'm sure there are browser plugins that allow social sharing of sticky notes, or comments on web pages.
                    Oh, yea... at least for Firefox. I mean to remember something like that.
                      Could this be something? https://addons.mozilla.org/en-US/firefox/addon/2792
                      Anyone tried it? Or got better solutions?
                        Point3d.project_to_plane:
                        http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#project_to_line
                        Shows the wrong example code (uses from project to line). and I know I gave the link for project_to_line. Its so you can see both methods simultaneously and see the error better. Thanks!
                          So far I am really truly enjoying the new docs. They feel much better, thanks for the efforts to get them to where they are. I'm also excited that changes might be able to happen faster now too, that is great.
                          I'm noticing that sometimes in the methods list, when I click on a method, it takes me to the class index for that method. Other times it willtake me directly to the entry for that method within the class. I prefer the latter. But I don't know why sometimes it does one thing and sometimes it does another,
                            Error 404 (Not Found)!!1
                            (code.google.com)
                            It doesn't mention how to allow drop-down options by using a third array with strings separating each option with a pipe | character.
                              You can do a dropdown box?
                                UI.inputbox ['Hello'], ['World'], ['Mars|Pluto|World|Monkeys'], 'Title'
                                "Global Material Changer" and "Component Spray" uses it. That's the only way I knew it was possible.
                                  Jim
                                  Sure, and I made this to ease the pain a little: http://sketchuptips.blogspot.com/2008/03/inputbox-class.html
                                    Nice one Jim.
                                      http://code.google.com/apis/sketchup/docs/ourdoc/point3d.html#z=
                                      It says:
                                      Point3d.z=
                                          The y= method is used to set the z value of a 3D point.
                                      That second line should say "The z= method..."
                                        (code.google.com)
                                        Face.area actually takes an optional argument. I'm not sure what the argument is. It accepts pure numbers which then seems to be a scale factor. But it also accepts Transformation objects.
                                          Same applies to Edge.length
                                            The example uses project_to_line
                                             plane = [Geom;;Point3d.new(0,0,0), Geom;;Vector3d.new(0,0,1)]
                                             point = Geom;;Point3d.new 10,10,10
                                             projected_point = point.project_to_line line
                                            • 18
                                            • 19
                                            • 2 / 19
