New API doc - typos and questions
Nice one Jim.
It says:
Point3d.z= The y= method is used to set the z value of a 3D point.That second line should say "The z= method..."
Face.areaactually takes an optional argument. I'm not sure what the argument is. It accepts pure numbers which then seems to be a scale factor. But it also acceptsTransformationobjects. -
Same applies to
Edge.length -
Point3d.project_to_plane
The example uses project_to_lineplane = [Geom;;Point3d.new(0,0,0), Geom;;Vector3d.new(0,0,1)] point = Geom;;Point3d.new 10,10,10 projected_point = point.project_to_line line -
Tool - onMouseMove example has a bad local variable.
http://code.google.com/apis/sketchup/docs/ourdoc/tool.html#onMouseMovedef onMouseMove(flags, x, y, view) puts "onMouseMove; flags = " + key.to_s puts " x = " + x.to_s puts " y = " + y.to_s puts " view = " + view.to_s endThe variable "key" should be replaced with "flag" I think. That makes the example work.
The code example:
model = Sketchup.active_model entities = model.active_entities pts = [] pts[0] = [0, 0, 0] pts[1] = [9, 0, 0] pts[2] = [9, 9, 0] pts[3] = [0, 9, 0] # Add the face to the entities in the model face = entities.add_face pts tw = Sketchup;;TextureWriter.new uvHelp = face.get_UVHelper true, true, twThis will return the error:
Error: #<TypeError: (eval):95:in `get_UVHelper': wrong argument type (expected Sketchup::TextureWriter)>
(eval):95Instead of
tw = Sketchup::TextureWriter.new, the methodtw = Sketchup.create_texture_writerwill work.
Which leads to another questions: why can'ttw = Sketchup::TextureWriter.newbe used as in the example? -
ModelObserver.onPlaceComponent
http://code.google.com/apis/sketchup/docs/ourdoc/modelobserver.html#onPlaceComponentThe manual claims that a
Modelis passed on as the argument, but instead it's theComponentInstance. I have not tested the rest of theModelObserverevents to see if they also match.onPlaceComponent FIXED
Modelis passed on as the argument, but instead it's theComponentInstance. I have not tested the rest of theModelObserverevents to see if they also match.Thomas, you rock.
I'll double check all of the modelobserver arguments. Thanks!
For
Point3d.distance_to_linethe docs give the same example aspoint3d.distance. -
I can't get the
DefinitionObserverto trigger at all. http://code.google.com/apis/sketchup/docs/ourdoc/definitionobserver.html Neither theonComponentInstanceAddedoronComponentInstanceRemovedevents. Are these the correct event names? -
I just had a big one reported to me... posting it here so folks are aware until the next fix.
The face.material method is entirely missing from the new docs.
There's a new update live that fixes (most of) the problems reported above. There were one or two that will require me to pound on it a bit more. Keep 'em coming!
I also posted a new tutorial on reading attributes.
Nice one Scott.
I seem to have come across three observer events that doesn't work. It would probably be useful to mark these in the docs with a warning so that people won't waste a whole lot of time trying to get them work work. ..like I have...
DefinitionObserverhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17631 (Completely busted)
EntitiesObserver.onContentsModifiedhttp://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17970 (Add and Remove event works though. Haven't tried the Erase event.) -
I also just got this one from a coworker:
Sketchup.get_resource_path example fails. Looks like there's a required parameter that's not properly documented.
-Scott
These failing observers is quite severe. I don't suppose there's a chance the dev team can push out an update outside the servicepack schedule? (I don't know what your schedule is, but seeing that we just got an servicepack I'm a bit pessimistic to when this might be addressed...)
A semi related typo:
in this tutorial pt4=[0,9,9] whereas it should be [0,9,0].
::OFF TOPIC::
All right Remus, come clean. Your always in the Ruby forum, you spotted a typo in tutorial, you answer questions once in a while....how much ruby do you know? Are you making plugins and selling them overseas for big money or something?Chris
Just saw another one: the Sketchup.break_edges= example is the Sketchup.break_edges? example.
Thom, step 1 with the observers is to confirm if it's the implementation that is broken or the documentation. Simone has filed A-list bugs against the observer problems you've found, and he and I have been chatting about it. Any fixes will have to wait until the next maintenance release.
Feel free to PM me if you want to brainstorm workarounds for what you're trying to accomplish. I know a few tricks.
Dont pretend your not in on it as well
on a more serious note, it seems a shame to miss out on the ever so powerful ruby based capabilities of sketchup, so i thought i'd try my hand at it and see if i got anywhere.
I reckon i could just about right a box making script at the moment
just as long as you dont want to change your box at all...
