    New API doc - typos and questions
    370 Posts 35 Posters 290.9k Views 35 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      _
      Model.title
      The tile method retrieves the name of the model. If the model is saved on disk, returns the file name without extension. Otherwise returns an empty string.
      http://code.google.com/apis/sketchup/docs/ourdoc/model.html#title
      Change 'tile' to 'title' in method description.
      We could use Model.is_saved? and Model.is_unsaved? methods, as the Model.title method is the only way (that I can find) to determine if the model has yet been saved or not. We cannot rely upon the word 'Untitled' (in the caption bar) because that may actually be a valid filename.
      Workaround:
      class Sketchup;;Model
      def is_saved?
        return not title.empty?
      def is_unsaved?
        return title.empty?
      end # class
      _
      I'm not here much anymore.
        Camera.set
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#set
        The initialize method is deprecated. It essentially does the same thing as Camera.set.
        Seems that's the description for Camera.new http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/camera.html#new
        ...and that Camera.new has the description for Camera.set
          View.pickray
          http://code.google.com/apis/sketchup/docs/ourdoc/view.html#pickray
          Returns:
          ray
          a ray
          "a ray"? Without testing this I#m guessing either a vector or line.
            Dan Rathbun
            @thomthom said:
            View.pickray
            Returns:
            ray a ray
            see this...
            Model.raytest
            A ray is a two element array containing a point and a vector [Geom::Point3d(), Geom::Vector3d()]. http://code.google.com/apis/sketchup/docs/ourdoc/model.html#raytest
            _
              Yea - I tested it later that day. It's what the Geom module describes as a line.
                Dan Rathbun
                Shouldn't the API have a definition for Line and/or Ray as a class (under the Geom module) ?
                something like:
                class Geom;;Ray < Array
                  def new(*args)
                    Array[Geom;;Point3d().new, Geom;;Vector3d().new]
                    super()
                  Line and Plane? hm... maybe... thought of that myself. but never really felt the need for it to make a request. works fine as it is.
                  Dealing with them as Arrays works ok. They are simple structures.
                    Dan Rathbun
                    Model.add_note
                    The note is not displayed unless there are entities in the model. If you add a note first thing in a new model, it is invisible but .visible? on the note object still returns true.
                    As soon as you draw something, the note appears.
                      Jim
                      Thanks Dan - yet more never-seen-before docs coming to light.
                        I have the mental image of Scott drowning in printouts from this thread... 😒 😆
                          Jim
                          Oh, I think there is a completely undocumented UTM class in there somewhere under Geom.
                            hm.. all I can find out about that one is:
                            Geom::UTM.instance_methods.sort.join("\n") (eval):894: warning: instance_methods: parameter will default to 'true' as of 1.8.1 to_a to_latlong to_s x y zone_letter zone_number
                              Jim
                              View.show_frame
                              Documentation for this method contains some poorly-parsed html tags.
                                Dan Rathbun
                                Geom::UTM.instance_methods.sort.join("\n")... snip ...
                                from Wikipedia search on "UTM":
                                Universal Transverse Mercator coordinate system, a grid-based method of mapping locations on the surface of the Earth.
                                http://en.wikipedia.org/wiki/Universal_Transverse_Mercator_coordinate_system
                                _
                                  Dan Rathbun
                                  Model.get_product_family
                                  http://code.google.com/apis/sketchup/docs/ourdoc/model.html#get_product_family
                                  Returns a constant number which indicates the product family of the installed SketchUp application.
                                  This is an Application related attribute, why is it part of the Model class?
                                  This should be a method of the Sketchup module as in: Sketchup.get_product_family
                                  _
                                    Dan Rathbun
                                    Model.export
                                    http://code.google.com/apis/sketchup/docs/ourdoc/model.html#export
                                    options_hash______ A hash containing the COLLADA (.dae) export options.
                                    The options listed in the hash example is missing the option for hidden geometry.
                                    The Registry Attribute Name is "ExportHiddenGeometry", but what is the options hash key?
                                    • hiddengeometry ?* hidden_geometry ?
                                      _
                                      Dan Rathbun
                                      Set class
                                      http://code.google.com/apis/sketchup/docs/ourdoc/set.html
                                      This class is defined in the Objectspace and should be listed under "Core Ruby Classes" (along with Array, Length, Numeric and String.)
                                      Instead it's buried under "App Level Classes" and listed with all those classes that are defined inside the Sketchup module.
                                      _
                                        Dan Rathbun
                                        OptionsProviderObserver.onOptionsProviderChanged
                                        http://code.google.com/apis/sketchup/docs/ourdoc/optionsproviderobserver.html#onOptionsProviderChanged
                                        The onOptionsProviderChanged method is invoked when an element is added to an Pages object.
                                        Should read, "The onOptionsProviderChanged method is invoked when an option is changed for an OptionsProvider object."
                                        _
                                          Entities.add_curve
                                          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_curve
                                          Returns an array of edges - not a Curve object.
                                            @thomthom said:
                                            Entities.add_curve
                                            Ita's the same as add_circle which returns an array od edges and to find the just made curves curve you use edges=entities.add_curve(array_of_points) curve=edges[0].curve
                                            But strangely not with add_arc which returns an ArcCurve ?
                                            It would be unadvisable to change what the API does with these add_ methods - rather it we should keep it as is and fix the API's Guide to reflect it properly - too many scripts already get the curve from the edges array and would fail if it were updated to return the curve not the curve's edges...
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
