    How to get a pixel value from an image file?
    9 Posts 4 Posters 971 Views 4 Watching
    • W Offline
      Whaat
      Is there a relatively simple way to do this? It does not seem possible with the SketchUp API or with the core Ruby methods. I suppose there are many methods using external DLLs but I am looking for something as easy as possible. I think it might be possible by using a WebDialog in combination with the HTML5 <canvas> element and some javascript, but I don't think the <canvas> element will work on Windows systems using a Webdialog.
      What I am after is getting the RGB values of a texture for a given pair of UV coordinates.
      Thanks.
      • P Offline
        Pixero
        I'm interested in this too. The only script I can think of right now is one that Didier Bur made to make displacement from a greyscale map. Maybe you can find something there?
          Thanks.
          Or maybe you can find some ruby libraries that allows you to read directly from the files.
          • W Offline
            Whaat
            I've looked around a bit. You would think there would be one but I think everyone Ruby library I have found is just a bridge to another library that was done in C++. (Maybe that's the only way it can be done...)
            Are you there Didier? I am sure you have some ideas. 😄
            • W Offline
              Whaat
              Do you have the link?
                I think it's the heightfield generator: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_fil_page.htm
                Scrambled plugins. But they don't read normal formats. Takes PGM or PPm formats: http://en.wikipedia.org/wiki/Netpbm_format
                  @whaat said:
                  Odd that there's be no proper ruby library. One, time-consuming way, would be to implement it yourself from the specifications. BMP, PNG, GIF and JPEG specs are available for anyone, I think TIFF is as well. But it's work, at least with the compressed formats. BMPs are pretty straight forwards though.
                  I was looking into these formats when I was working on a PHP thumbnail extractor.
                    You had a look at this one? http://pikl.rubyforge.org/
                      RickW
                      Yet another bridge to a C++ library... (sigh)
                      RickW
                      [www.smustard.com](http://www.smustard.com)
