Vray Problem - objects missing
Hi, have you encountered the same problem? Its weird that some objects are missing in my rendered image. I changed the material from default to shiny silver and when I rendered it's gone. Pls help! Thanks!
Yes. It's a known problem.
Solution depends on what V-Ray for Sketchup version you have:
In the original version, groups has a tendency to not render. You could either explode and re-group or do Make Component to make it render. I got into the habit of always making components instead of groups, at the expense of a more cluttered component browser.
In the SR1.x releases it's somewhat different. Some groups won't render after you create or edit them. But if you reopen the file they will render again, without the need to explode or convert to components. Note that you don't have to restart SU, you only need to go File->New, create a new model, then reload the file you where working on. (I'm not sure if this only occur to groups, or also components.)
I see.. I didn't know that. I ungrouped it and it's ok now. Thanks alot!
No problem.
There's a few quirks in VfSU. The ASGVis forums are a good resource to find ways to deal with them.What version do you have by the way? The original?
Register LoginAdvertisement
