    Hidden_not hidden?
    9 Posts 4 Posters 973 Views 4 Watching
    • X Offline
      xrok1
      look at this picture, pay close attention to selected geometry and info box.
      i can't get this unhidden no matter what i do, any ideas? 👊
      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
        Aidus
        Open Outliner Box and unhide there 😄
        This is when object is hidden but layer is not.
        CPU: Intel Core i7 Extreme Edition 965
        RAM: OCZ Gold DDR3 1600MHz 12Gb
        Video: Asus Radeon HD4870 X2 2Gb
        Mobo: Asus P6T Deluxe 1366 Intel X58
        • X Offline
          xrok1
          didn't show as hidden in outliner either.
          or on right click, or in the menu when i clicked unhide all??
          i finally exploded the group, right click, then unhide was availiable; regrouped.
          looks like a bug, maybe someone could move this posting.
            Aidus
            Example.
            I have group wich contains 3 types of components. When i hide one type of component in Outliner window then that component is showing up like in Your screenshot.
            Open Window -> Outliner and there unhide everything.
            • X Offline
              xrok1
              that geometry is all in one (top level) group, the file only contains four groups, and the four groups all showed as visible in the outliner.
                Aidus
                Can you post that su file?
                  Isn't it that you've wrapped a group around your hidden geometry?
                    That's my guess, too. If there is some hidden geometry inside the group, when you click on the group, it won't show hidden since the group itself is not hidden.
                    Note that the Outliner won't list your raw (ungrouped) geometry so no wonder you couldn't see it there.
                    Also, if you go to Edit > Unhide (...whatever), it will only unhide geometry in the same context you are in - eg. if outside the group, all ungrouped (and hidden) geometry, if inside the group, all that's inside - but only that's inside.
                    • X Offline
                      xrok1
                      after reading your posts i did some experimenting and it turns out that i must have selected all then hide while inside the group. wierd, i wouldn't expect it to work that way.
                      thanks for the replies, that could've caught me again down the road cause i had no idea why it happened. 👍
