🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Can't work with SketchUp --> Vue 7
extensions
6 Posts 5 Posters 1.2k Views 5 Watching
  • I Offline
    ibon
    Hi sketchucation friends. I've recently started using Vue7 and it's an amazing program, i would like to use with sketchup. I'm an architecture student, and i use to make my projects in sketchup. I would like to import them into Vue and add a realistic vegetation and environment.
    I've trying to do it but i'm not able. I have noticed that:
    • Vue7 can't import SketchUp 7 models (File --> Import Object...)
    http://img142.imageshack.us/img142/2974/car1tn7.th.jpg
    • When I import a model from SketchUp 6, model's components or parts go away!
    http://img291.imageshack.us/img291/4561/car2sn3.th.jpg
    • When I try to import a quite big SketchUp 6 file (20mb) it says that can't read that file
    http://img291.imageshack.us/img291/7827/building1hk4.th.jpg
    This is the model i'm trying to import (i've tried with a lots of more). I think it hasn't very much components.
    http://img145.imageshack.us/img145/3096/building2cw9.th.jpg
    • I've tried exporting the file as .obj and as .3ds, but when Vue7 imports them (after 20min) it can't handle them, it seems that they're very heavy for vue.
    • I've tried exploding whole model, but does't work. Sincerelly I don't know what to do, Vue is a very good program, but i can't find the way to make a workflow with SketchUp. Your helt would be very apreciated. many thanks!
    • K Offline
      kwistenbiebel
      This is a question for Solo I think.
      He knows his way around in Vue as no other SU user.
      My guess is however, he would pass the file through Deep exploration before taking it into Vue.
      • E Offline
        EarthMover
        Ibon, I export from SU to Vue 7 all the time. I've only ever had one model where it was an issue.
        I know Solo uses Deep exploration to convert .skp to .3ds.
        I find it just as easy to export out of sketchup as an .obj file. I made this tutorial for someone on another forum a while back - http://vimeo.com/2730211
        It shows how I do it.
        It should be very similar to the way you get a model in hypershot.
        Content Creator at Skapeup
          AndriyG81
          very unusual results. I did have problems with importing some skp files, but 3ds and obj worked well for me.
          Lately I use Collada to bring my files to vue 7, works great, give it a shot.
          http://andriyg.com
            sliner
            Convert components into groups, Vue does not understand them, though one can import, but if you use the DeepExploration, remove hierarchy of the selected components. 3ds obj reads well, I opened a file 80 MB and 2 million polygons.
            http://fancyquest.ru/albums/yucca/
            • I Offline
              ibon
              Thanks for your help, guys. I've been able to sucesfully load the model into Vue! Your tutorial is great Adam, thanks for it 😉
              What can I say... THANKS!!!
