    Choppy and jerky flythroughs
    17 Posts 7 Posters 3.9k Views 7 Watching
      JHuman
      Does anyone know the best settings to get a nice smooth flythrough out of SU. I always have a problem when it gets to the page it looks like it hits a wall and bounces back, then continues on its way. I dont want our client to get scared. I am using VRAY to render the scenes. Anyone know the best way to keep a consistent height and speed, some of the RB's will do that but dont work with an external render.
      Thanks!
      • Doweth!
      • K Offline
        kwistenbiebel
        It is possible but very very tedious.
        Look here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=13498&st=0&sk=t&sd=a&hilit=walkthrough
        (Go for Plot-Paris' post as he explains it quite well)
        downsides: You won't be able to animate a changing sun position (time of day) and neither the field of view (fixed zoom).
        All in all, the methods described aren't very suitable.
        It is a Sketchup handicap.
          JHuman
          I have tried this, and bought the plugins, still cant figure it out 100% A lot of these plugins work great inside of SU, but not with VRAY, since it exports the images. I will keep testing...
          • Doweth!
          • K Offline
            kwistenbiebel
            It does work using Vray.
            when all the different scenes are made, set the animation transition time in SU to 1 second (no delay).
            In the Vray animation settings, set the fps to 1.
            Each scene represents 1 frame of animation. So you would need x number of scenes for an animation of x frames.
            But again, the whole procedure is completely counter-intuitive, not Sketchup like at all.
            An animation method using a simple timeline and basic keyframing would be much better.
              JHuman
              Thanks biebel,
              It does work, just ran a test on a schematic model. Takes a little backwards thinking. I have read that tutorial you directed me to yesterday but i read it a few more times and it started making a bit more sense. Thanks!
              • Doweth!
              • plot-parisP Offline
                plot-paris
                yes, I know. I should write a proper tutorial at some point. but somehow I keep the silent hope, that this will not be necessary eventually, once Google addresses the lack of animation capabilities of SketchUp or one of the Ruby Masters hears Kwistenbiebel's and my prayers and faces the huge challenge of making SU more capable in that area. 😉
                • K Offline
                  kwistenbiebel
                  Don't count on Google.
                  They lost the key to the vault (read: core code).
                  It will totally depend on ruby masters. My guess is that a plugin written using ruby would slow things down even more though....
                    linea
                    The only success (success being a relative term) I have had with animating SU models is with Kerkythea, it's really simple. I then compile the frames in Paint Shop Pro's Animation Shop.
                      chango70
                      What about SU Animate? I haven't really tried it yet but does it not work with VRay?
                      • Jean LemireJ Offline
                        Jean Lemire
                        Hi JHuman, hi folks.
                        Go to View Menu --> Animation --> Settings
                        After you have enabled scene transition and set some time to get a nice transition from one scene to another, set the "Scene delay" to 0 to keep the movement going smoothly and avoid it from stopping at each scene.
                        Just ideas.
                        • K Offline
                          kwistenbiebel
                          I think I said that in a previous post above.
                            plot-paris
                            @Jean,
                            the problem is, that the curve from scene1 to scene2 does not lead smoothly into the curve from scene2 to scene3. therefore there will always be an abrupt change in direction.
                            I think that is something a Ruby could fix 😉
                            • create a smooth transition curve for the camera movement between scenes
                            • let the user change the smoothness of the curve
                              JHuman
                              Exactly! Thanks, I have been using your animation tutorial and it works out now. Thanks!
                              • Doweth!
                              • K Offline
                                kwistenbiebel
                                The funny thing is that in 3DsMax and Cinema4D setting up a smooth camera animation is much easier than in Sketchup.
                                Simply keyframe your camera positions on the timeline. It will connect an editable spline between the camera positions and you are done.
                                  Jean Lemire
                                  Hi Kwistenbiebel, hi folks.
                                  Sorry, you are rigth, you stated "No delay". However, the 1 second between scene is a choice. I did an animation using 5 seconds and 19 scenes. The result was not extremely fluid but was acceptable. Of course, using more scenes and a shorter transition time like 2 seconds or even one, will produce a much better result. Experimentation is needed here.
                                  Just ideas.
                                  • K Offline
                                    kwistenbiebel
                                    That would mean having an animation of 4 frames per second.
                                    A good framerate generally is considered to be between 20 and 30 fps.
                                    • soloS Offline
                                      solo
                                      The higher the frame rate the smoother the animation, and the longer the render.
                                      • waiting for the day instant render happens *
                                      http://www.solos-art.com
