    Removing a single layer from multiple scenes
    8 Posts 3 Posters 912 Views 3 Watching
    • O Offline
      OrkinYards
      I am working on a model that has a lot of different street sections in it. Once I add a new section and isolate that section with a layer name that layer is added to ALL of my scenes. Is there a way to remove one layer from multiple scenes at once?
      Thanks!
        Hi OY,
        Better to create a layer that is hidden on each existing and future layers (and only turn it on where needed) than deleting (more exactly turning off) in each scene. Here is a nifty plugin for that.
        • O Offline
          OrkinYards
          I'm afraid that won't give me the control over the information that I need.
          If I end up having LOTS of hidden groups in one layer how can i unhide just one or the other? I suppose maybe the outliner would help with that if i named my groups - I'm used to creating a section, copying it up, creating a layer and naming it what the scene will be called and then putting that group on that layer giving me the ability in scene 1 Street A Before to have that layer on and then in Scene 2 Street A After to have that layer on - then when i go to create the next street I can just copy and create a new group and modify it - now that group/layer will show up in every scene created PRIOR to that point which is the issue.
          how does hiding groups instead of layering help with that?
          Thanks!
          • O Offline
            OrkinYards
            any chance you can post that *.*rb file here - my work internet is blocking my access to it
            • EdsonE Offline
              Edson
              there you go. and have a look at this thread too.
              add_hidden_layer.rb
              http://www.mahfuz.arq.br
                It doesn't add hidden groups but a hidden layer. Here is the script and try it out.
                add_hidden_layer.rb
                • O Offline
                  OrkinYards
                  good stuff - I think that should fix the problem I've been having...will use on my next model for sure!
                    Yeah, by what you wrote, you should adjust your workflow a bit but I think it could be of much help and use.
