    Oalexis' WIPs
    34 Posts 6 Posters 7.9k Views 6 Watching
    • O Offline
      oalexis
      Forgive me if the quality on this isn't up to par as I'm relativly new here. Just something I'm working on, inspired by the robot competition but, definitely not under a half hour. I'll be adding more stuff to this thread as I go along. This robot isn't quite finished yet
      Cheers,
      Orion
        remus
        Very impressive, and definitely up to par. You planning on rendering it?
        • H Offline
          Huggkruka
          That looks awesome even as SU! You should try the Hypershot trial, it would give some amazing iRobotic results! ๐Ÿ˜‰
          • O Offline
            oalexis
            Thanks remus and Huggkruka, I finished the model and here are some basic renders. I downloaded the hypershot trial but I can't get my models into the program. It says they open but the screen is just black. I've tried opening the files directly and using the hypershot exporter but neither seems to work. Any suggestions? Heres another thing i've started in the meantime, its some sort of satellite.
            • O Offline
              oalexis
              Ok I think i'm getting the hang of hypershot. Here are 4 test renders I did on the robot. Heres the model if anyone else wants to have a go with it.
              I think this one is the best
              Hello Dave...
              Robot.skp
              • O Offline
                oalexis
                I'm working a new scene now. Its still a WIP. I'm using the hypershot demo
                • O Offline
                  oalexis
                  update on the room
                  • O Offline
                    oalexis
                    Heres the final on the room done with hypershot. Sadly i can't add an interior light because i can't create a .hdr file without photoshop and i only have elements.
                    • O Offline
                      oalexis
                      working on a model of a canyon, going to try and make it realistic. Just roughing in the basic shapes so far
                      • O Offline
                        oalexis
                        well i did a "simple" model of a light from the game half life 2... applying the texture in SU took forever due to the complex nature of the object. I know its not much but I thought I'd post it up since it took so long. Rendered it in podium
                        • O Offline
                          oalexis
                          heres a little test animation of the scene i'm setting up. First time i've done something like this. It was rendered in podium; still getting used to the program
                          http://i41.photobucket.com/albums/e258/oalexis/testscene.gif
                          • X Offline
                            xrok1
                            how did you get the ground to look like that with podium ๐Ÿ˜ฎ thats awsome! could you post the settings or the file?
                            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                            • O Offline
                              oalexis
                              heres a little file i made to recreate the same look of the picture posted. Rendered on default in podium 1.6 with the quality and smooth sliders set to halfway.
                              Also heres a close up render of the forcefield fences in the animation
                              podium_settings_demo.skp
                              • X Offline
                                xrok1
                                thats excellent, thankyou very much.
                                thats about the best ground texture i've ever seen. where's it from?
                                • O Offline
                                  oalexis
                                  It's from the half life 2 game. It's possible to get all the textures out of the game as well as all the other source games. It only requires two programs to do so. GCFScape, and VTFEdit ๐Ÿ˜„
                                  • X Offline
                                    xrok1
                                    i can't get over how well it bumps. i opened it in PS cause i thought for sure it was coming from the alpha channel but NOOO.
                                    BTW, i love the trick with the semi transparent lens over the robot dogs eyes, it makes the red eyes appear as though they are glowing inside SU without even being rendered. [hats off]
                                    • O Offline
                                      oalexis
                                      Thanks xrok1 ๐Ÿ˜„ Heres a building from today.
                                      http://i41.photobucket.com/albums/e258/oalexis/row_house.gif
                                      • O Offline
                                        oalexis
                                        some other stuff i'm playing around with. I'm learning kerky now as well, seems to be a great program! ๐Ÿ˜„ I like the volumetric lighting feature
                                        • honoluludesktopH Offline
                                          honoluludesktop
                                          Thanks for positing your model, and renders. Did a quick one because I always like to see what my standard setup can do in comparison to others. Your render is more dramatic. Be nice if the materials were distressed.
                                          • O Offline
                                            oalexis
                                            some assests i made for use in a crysis map ๐Ÿ˜„ pics taken in the cryengine 2
                                            • 1 / 2
