    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 391.9k Views 154 Watching
    • W Offline
      Whaat
      Time for an update of Zorro. I think this release is much more polished than the first one. Plus, you now finally have the ability to render section cut views.
      New Features:
      -made cuts work with parallel projection views
      -added slice model at section plane (right click on a section plane for context menu)
      -added nested cuts using CTRL modifier
      -improved precision of cuts
      Somes notes on this release:
      • It is recommended to use 'Slice model at Section' on a backup of your SKP file. It is a destructive process.
      • Cutting through nested components results in creation of many unique components
      • Some code was used with permission from TIG's SectionCutFace script to create a cutting plane from a section plane. Thanks!
      • Script should work for older versions of SU and also on Mac systems
      I am calling this a beta version so please post any bugs or requests in this thread. Enjoy!
      EDIT: Updated version now attached which should fix the problems that have been reported. Also added tutorial.
      Whaat
      Get the latest RBZ version from the SCF PluginStore...http://sketchucation.com/pluginstore?pln=Zorro2
      Section cut render
      Zorro2.rb
      Zorro2 Tutorial.pdf
      G 1 Reply Last reply Reply Quote 0
        Seems that I was the first to download - willplay and give feedback as much as possible. Thanks Dale for this major upgrade; I'm especially interested in this section cut effect (I love TIG's script as well).
        Also, this seems to be a special day again with these real presents you guys spoil us with!
        • K Offline
          kwistenbiebel
          Wowoooooow
          Thank you Whaat!
          Looks very cool and I am sure to try it out. 👍
            remus
            Damm work getting in the way of playing around with your latest cool update!
            • CadFatherC Offline
              CadFather
              superthank you Whaat - this is a great plugin - always one of my favourites
              just putting my cape on now.. 😎
              Z
              PS ( i guess it will go into subsmooth in due course?)
              • MALAISEM Offline
                MALAISE
                Let's play with this version, feedback very soon !
                MALAISE 👍
                Just a try
                The former version worked perfectly ( SU V6 and V7 ).
                Using Zorro2 when trying to cut a simple box even a group, the white feather
                is gluing to the cut line, and nothing happens.
                back to Zorro.rb (1), all work perfectly.
                I hope it's help 😄
                  Zorro return! 😎
                    bianhai
                    This is a great plugin! 👍
                    Thank you Whaat!
                    Today is China's Spring Festival, to say hello!
                    • FrederikF Offline
                      Frederik
                      THANKS Whaat'sUp... 😄
                      Cheers
                      Kim Frederik
                      • W Offline
                        Whaat
                        @malaise said:
                        Hi Whaat
                        Some difficulties using Zorro2. No cutting effects, the white feather is gluing to the cut line.
                        Let's see my previous post.
                        MALAISE 😄
                        Can you post the SKP file? Are you sure you are in group-edit mode when you are doing the cut?
                          linea
                          One of my most used scripts just got better!
                            Seems works not with the orthogonal view (parallel projection)! 😮
                            Works fine with normal view and 2 points perspective 😉
                            Request : a little tut video! 😄
                            Question: why not name the new Zorro file: zorro2.rb ?
                            • W Offline
                              watkins
                              Dear Dale,
                              I too would like to see a video tutorial, or a .pdf help file explaining the various options.
                              Kind regards,
                              Bob
                              • W Offline
                                Whaat
                                I guess I created a small bug just before I released the plugin that I did not release was there. i will post a fixed version later today. Sorry! I will also try to create a tutorial later today if I have time. For those of you who do not want to wait, just change line 266 to read:
                                Sketchup.active_model.start_operation("Zorro")
                                I belive this will fix the problem but I don't have time to fully test right now.
                                • MALAISEM Offline
                                  MALAISE
                                  Hi Whaat
                                  some feedback, I've just notice your last post.
                                  It seems that something may be corrupted
                                  MALAISE 👍
                                  • W Offline
                                    Whaat
                                    OK, I updated the plugin in the first thread and added a tutorial. Hope that all works now...
                                    • K Offline
                                      kwistenbiebel
                                      I draw the cut line by clicking two points but it doesn't cut. (using the updated version)
                                      • W Offline
                                        Whaat
                                        Any errors in the Ruby Console?? Did you read the tutorial?
                                        • MALAISEM Offline
                                          MALAISE
                                          Hi Whaat
                                          It works perfectly. Slide model at section is really a good improvement. ☀
                                          MALAISE 👍 👍
                                            rv1974
                                            immensely 👍
                                            PS Dale could you add create section cuts from multiplesections all together at once?
                                            • 15
                                            • 16
                                            • 1 / 16
