    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 412.3k Views 154 Watching
      remus
      Damm work getting in the way of playing around with your latest cool update!
      • CadFatherC Offline
        CadFather
        superthank you Whaat - this is a great plugin - always one of my favourites
        just putting my cape on now.. 😎
        Z
        PS ( i guess it will go into subsmooth in due course?)
        • MALAISEM Offline
          MALAISE
          Let's play with this version, feedback very soon !
          MALAISE 👍
          Just a try
          The former version worked perfectly ( SU V6 and V7 ).
          Using Zorro2 when trying to cut a simple box even a group, the white feather
          is gluing to the cut line, and nothing happens.
          back to Zorro.rb (1), all work perfectly.
          I hope it's help 😄
            Zorro return! 😎
              bianhai
              This is a great plugin! 👍
              Thank you Whaat!
              Today is China's Spring Festival, to say hello!
              • FrederikF Offline
                Frederik
                THANKS Whaat'sUp... 😄
                Cheers
                Kim Frederik
                • W Offline
                  Whaat
                  @malaise said:
                  Hi Whaat
                  Some difficulties using Zorro2. No cutting effects, the white feather is gluing to the cut line.
                  Let's see my previous post.
                  MALAISE 😄
                  Can you post the SKP file? Are you sure you are in group-edit mode when you are doing the cut?
                    linea
                    One of my most used scripts just got better!
                      Seems works not with the orthogonal view (parallel projection)! 😮
                      Works fine with normal view and 2 points perspective 😉
                      Request : a little tut video! 😄
                      Question: why not name the new Zorro file: zorro2.rb ?
                      • W Offline
                        watkins
                        Dear Dale,
                        I too would like to see a video tutorial, or a .pdf help file explaining the various options.
                        Kind regards,
                        Bob
                        • W Offline
                          Whaat
                          I guess I created a small bug just before I released the plugin that I did not release was there. i will post a fixed version later today. Sorry! I will also try to create a tutorial later today if I have time. For those of you who do not want to wait, just change line 266 to read:
                          Sketchup.active_model.start_operation("Zorro")
                          I belive this will fix the problem but I don't have time to fully test right now.
                          • MALAISEM Offline
                            MALAISE
                            Hi Whaat
                            some feedback, I've just notice your last post.
                            It seems that something may be corrupted
                            MALAISE 👍
                            • W Offline
                              Whaat
                              OK, I updated the plugin in the first thread and added a tutorial. Hope that all works now...
                                kwistenbiebel
                                I draw the cut line by clicking two points but it doesn't cut. (using the updated version)
                                • W Offline
                                  Whaat
                                  Any errors in the Ruby Console?? Did you read the tutorial?
                                  • MALAISEM Offline
                                    MALAISE
                                    Hi Whaat
                                    It works perfectly. Slide model at section is really a good improvement. ☀
                                    MALAISE 👍 👍
                                      rv1974
                                      immensely 👍
                                      PS Dale could you add create section cuts from multiplesections all together at once?
                                        Absolutly brilliant and so easy to use! 😎
                                        Just for quibble "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")" 😉
                                          kwistenbiebel
                                          I deleted the old zorro.rb and now it works.
                                          Thank you again for this plugin.
                                          • MALAISEM Offline
                                            MALAISE
                                            Hi Whaat
                                            Some difficulties using Zorro2. No cutting effects, the white (feather 😆 ) arrow is gluing to the cut line.
                                            MALAISE 😄
                                            • 15
                                            • 16
                                            • 1 / 16
