    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 430.7k Views 154 Watching
    • W
      Whaat
      @malaise said:
      Hi Whaat
      Some difficulties using Zorro2. No cutting effects, the white feather is gluing to the cut line.
      Let's see my previous post.
      MALAISE 😄
      Can you post the SKP file? Are you sure you are in group-edit mode when you are doing the cut?
      • L
        linea
        One of my most used scripts just got better!
          Seems works not with the orthogonal view (parallel projection)! 😮
          Works fine with normal view and 2 points perspective 😉
          Request : a little tut video! 😄
          Question: why not name the new Zorro file: zorro2.rb ?
          • W
            watkins
            Dear Dale,
            I too would like to see a video tutorial, or a .pdf help file explaining the various options.
            Kind regards,
            Bob
            • W
              Whaat
              I guess I created a small bug just before I released the plugin that I did not release was there. i will post a fixed version later today. Sorry! I will also try to create a tutorial later today if I have time. For those of you who do not want to wait, just change line 266 to read:
              Sketchup.active_model.start_operation("Zorro")
              I belive this will fix the problem but I don't have time to fully test right now.
              • MALAISEM
                MALAISE
                Hi Whaat
                some feedback, I've just notice your last post.
                It seems that something may be corrupted
                MALAISE 👍
                • W
                  Whaat
                  OK, I updated the plugin in the first thread and added a tutorial. Hope that all works now...
                  • K
                    kwistenbiebel
                    I draw the cut line by clicking two points but it doesn't cut. (using the updated version)
                    • W
                      Whaat
                      Any errors in the Ruby Console?? Did you read the tutorial?
                      • MALAISEM
                        MALAISE
                        Hi Whaat
                        It works perfectly. Slide model at section is really a good improvement. ☀
                        MALAISE 👍 👍
                          rv1974
                          immensely 👍
                          PS Dale could you add create section cuts from multiplesections all together at once?
                            Absolutly brilliant and so easy to use! 😎
                            Just for quibble "main_menu.add_item("Zorro")" must be "main_menu.add_item("Zorro2")" 😉
                            • K
                              kwistenbiebel
                              I deleted the old zorro.rb and now it works.
                              Thank you again for this plugin.
                              • MALAISEM
                                MALAISE
                                Hi Whaat
                                Some difficulties using Zorro2. No cutting effects, the white (feather 😆 ) arrow is gluing to the cut line.
                                MALAISE 😄
                                  derryatlanta
                                  Thanks so much, Whaat.
                                  Superb job developing and packaging this ruby. I look forward to checking it out today.
                                  Cheers,
                                  Nigel
                                  Stop your grinnin' and drop your linen
                                    sepo
                                    Thanks for the really good and useful plugin. Is there any chance to have closed section when using with SU section tool.
                                      materialdb
                                      THATS What I've been looking for! Thanks a lot!
                                      free vismat materials: http://www.material-db.com
                                      • C
                                        craigbic
                                        Awesome plugin! The ability to slice along a section cut face is FANTASTIC! Been waiting for something like that for a while now. Thank you so much!
                                        Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
                                        • jim smithJ
                                          jim smith
                                          Thank you, again, Dale great tool!
                                          "Out of clutter find simplicity,
                                          from discord find harmony,
                                          In the middle of difficulty lies opportunity"
                                          Albert Einstein
                                          • C
                                            cyan.archnet
                                            THANK YOU!, will definitely give this awesome plugin a try!
                                            • 15
                                            • 16
                                            • 1 / 16
