    Moving Points
    6 Posts 4 Posters 555 Views 4 Watching
    • S
      ShipAddict
      Patrick.H is currently teaching me to make ship hulls using the method in his topic:
      http://www.sketchucation.com/forums/scf/viewtopic.php?f=81&t=14861
      However when I try and pull out th hull to make the bow, it just refuses to come out.
      This is a picture from Patrick's topic:
      http://i286.photobucket.com/albums/ll114/paddy3443/007.jpg
      Here is what mine does:
      http://i377.photobucket.com/albums/oo216/ShipAddict/Liner1.jpg
      I am following each step exactly as I should.
      I have tried it on a laptop, and the same thing happens. I have even downloaded SU Pro trial but it still will not work.
      I'm sorry but i'm not very happy and would like to know why the program isn't doing what I thought and assumed it would do.
      Any help would be much appreciated,
      Thanks,
      SA πŸ˜„
      • Wo3DanW
        Wo3Dan
        SA,
        Did you try locking directions when pulling these points?
        Have no geometry selected, only the 'Move' tool.
        Hover over the point to be moved.
        Click and dragg it out. While doing so hit left arrow key for locking to green or right
        arrow key for locking to red directions. (up/down arrows are for blue direction)
        Does this solve the problem?
        Wo3Dan
        • GaieusG
          Hi Taff,
          You didn't use to be rolling like that 😲
          http://www.sketchucation.com/forums/scf/download/file.php?avatar=145_1228513282.gif
          (Sorry SA for the OT post)
          • TaffGochT
            TaffGoch
            'Tis true -- but note anti-clockwise animation, to fit my contrarian nature πŸ˜‰
            "Information is not knowledge." -- Albert Einstein
            • TaffGochT
              TaffGoch
              SA,
              Don't select any geometry before you try the move (as Wo3Dan intimates.) If you switch to the 'Move' tool with no entities selected, individual entities will 'highlight' as you pass the cursor over them -- with one great big PLUS! -- Endpoints can be highlighted and moved!
              Normally, you can't select endpoints, but using the 'Move' tool, you can. It looks like, from Patrick.H's instructions, that he is moving individual endpoints to 'eyeball' a new location. Along with Wo3Dan's axis-locking tip, you can play with endpoint positions to create and fine-tune curved lines and surfaces.
              See the 'Move' tool description here, for an animated depiction of the technique:
              http://groups.google.com/group/SketchUp/web/faqs-for-learning-more-advanced-tips-and-techniques#TweakSculpt
              Regards,
              Taff
              • S
                ShipAddict
                @gaieus said:
                Hi Taff,
                LOL, no problem πŸ˜„ πŸ˜›
                Hi guys,
                Thanks for your replies πŸ˜„
                They didn't work until I thought i'll try pulling on another Axis as such, so I rotated the model, and then I was able to pull the points out ;D
                Now just got to get the hang of this method!
                Thanks very much for your help!
                SA πŸ˜„
