    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 34.5k Views 61 Watching
    • fredo6F Offline
      fredo6
      @jmmad said:
      Do you think you could add more transformations to it, like bend, twist, Bulge
      Maibe for a comercial plugin?
      [attachment=0:gebfklnj]<!-- ia0 -->Transforms.jpg<!-- ia0 -->[/attachment:gebfklnj]
      I can add shear and twist without too much problem. But the royal way to all these deformations is definitely Sketchy FFD.
      • K Offline
        kwistenbiebel
        [attachment=0:3oyx96kl]<!-- ia0 -->Transforms.jpg<!-- ia0 -->[/attachment:3oyx96kl]
        Please add it Fredo. 👍
        I find your plugin to run more smoothly and controllable than FFD.
        Shear and twist would be wonderful as a tool.
        By the way, since I installed your plugin,I never use the default SU scaling tool anymore.
        The plugin is fantastic and works very intuitive.
        Thank you again.
        • soloS Offline
          solo
          +1 for sheer and twist.
          http://www.solos-art.com
            jmmad
            I Know FFD is very powerful for deformation tool, but its not as fast and easy to use as your Taper Deformation Script.
            with FFD it is very hard to do an accurate bend or twist, also you canot deform Nested Components or Grups, and you canot align the deformation as easy as you can do it with Taper deformation in your ruby.
            Get Upa !
              Daniel S
              Fredo already post a shear transformation plugin that works very well.
              Click here: PlaneShear
              It`s not very popular because it´s inside a question topic.
              Daniel S
              • fredo6F Offline
                fredo6
                @daniel s said:
                Another problem that I have is when trying to scale Red, Green, Blue (all togheter) with a negative number.
                I attach a video showing this.
                In the video you will see that if I try to scale only red axis negative, only green negative or only blue negative all works well... but if I take a red blue and green grip to a negative number it turns crazy. The same happens if I press the ctrl key. It works well if I scale one axis only.
                Daniel S
                Daniel,
                Another interesting bug (due to Sketchup precision reaching limits). I hope I hav fixed them (you had one for Taper with negative scales too)
                Would you mind to try with this updated version.
                Thanks very much
                Fred
                to drop in FREESCALE_Dir_10
                  jmmad
                  Daniel S
                  How could i missed a Fredo Script ?
                  OMG Shear works great Im impresed 2 times by you Fredo in a day, and nice icons you made last year for it Daniel.
                  Fredo the only thing i miss in shear deformation is that it groups the shear object at the end, in your Taper deformation that does not happen so you can deform part of an object without breaking it in 2.
                  It would be amazing to bend, twist, shear, bugle just part of an object.
                  That way Organic Modeling would be like playing with clay in SU,
                  Thxs to so talented scripters like you
                  Get Upa !
                    Daniel S
                    Fredo,
                    This new version fixes all the problems in the scale tool in all the axis.
                    I didn´t try before the Taper with negative scales. Seems that now there is a problem only if you try to Taper with negative scales about center (pressing the Ctrl key). All the rest works very well.
                    I attach a video of this too.
                    Thank you,
                    Daniel S
                    Taper with negative scales about center problem video .wmv
                    • majidM Offline
                      majid
                      just to sow my respect to u 😄
                      majid
                      • Y Offline
                        Yanman
                        Fredo6
                        Thank you! THANK YOU!!!very very VERY much Fredo6
                        • H Offline
                          Heven7_floor
                          Thanksyou Fredo ,it 's wonderful script, good idol of SU plugin for me ,I like it ,thanks again. 👍 👍 👍
                            Rodentpete
                            Great work with this very useful sript, Google really needs to give you a job!
                            • F Offline
                              Fletch
                              I've been begging for this for years... and here it is...
                              Fredo! You rock, my friend! Fantastic! Thanks so much for sharing!
                              Fletch
                              Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                              • fredo6F Offline
                                fredo6
                                NEW UPDATE 02 FEB 09
                                I have posted an update to FreeScale and to LibFredo6.
                                It mainly fixes some problems of stability when scaling or tapering with negative factors, as well as minor issues here and there.
                                Please make sure you update both
                                FreeScale 1.0c--> http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16021#p124685
                                LibFredo6 3.0c --> http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16020#p124684
                                Thanks to all for your warm support and your contribution to testing this very first version of FreeScale. I hope to add a few features soon in the future, hopefully.
                                Fredo
                                • fredo6F Offline
                                  fredo6
                                  NEW NEW UPDATE - 3 Feb 09 - 00:20
                                  There was a big bug in my previous update 1.0c (Scale about center did not work any longer). Sorry for that.
                                  Please make sure you download the version **1.0d**in the main thread.
                                  Sorry again. I hope this one will be stable again.
                                  Fredo
                                  • Chris FullmerC Offline
                                    Absolutely fantastic. One of the tools I've also thought should just be included in SU by default. Thanks so much!
                                    Chris
                                    All my Plugins I've written
                                      blugarero
                                      This is so useful. Thank you very much for your efforts. AWESOME!!!
                                      • PixeroP Offline
                                        Pixero
                                        Thanks Fredo. I can see tons of use for this plugin.
                                        Question: Would it be possible to have a "object oriented" move tool with a gizmo. It would be very useful for positioning object. Maybe a switch in the tool between world coord and object space coords (rotated object directions).
                                        • erikBE Offline
                                          erikB
                                          Thank you very much Fredo.
                                          It has allready been very handy !!
                                          erikB
                                            James Fraser
                                            First: thanks Fredo, this plugin is going to make a lot of things a lot easier and quicker. I could have used taper on some recent things and being able to reorient the scaling box is something I will use all the time.
                                            Second: how it works on the Mac. I didn't see many people writing about this, so I thought I would let you know. The good news is that generally works fine, the only problem is a couple of UI things. The web dialogs do display, but it fills the bottom half of the window with nothing (presumably stretching the little blankspace border you normally get around things), but you can get around this by resizing the window until you see everything.
                                            The slightly bigger problem for me is labels. The mouseover description works fine, but the labels under icons are blank (when I turned them on), in the menu there are four blank lines, which work for selecting the tools, but have no names and I do not get anything in the flyout from the context menu (I mean there isn't a flyout, but there should be, the Freescale thing is there, but nothing happens). I don't care about the labels per se, but I use keyboard shortcuts a lot and without a label there is nothing to bind it to (I want to replace S for the normal scale tool 😄 ).
                                            The only thing I can think of off the top of my head would be a filename/case sensitivity problem, as that is more likely to affect OS X than Windows (which I think is still case insensitive, at least most of the time). You will probably know better than me, though.
                                            http://www.FormFonts.com
                                            • 6
                                            • 7
                                            • 5 / 7
