    [Obsolete] FredoScale 1.0e (Free Scaling, Taper Scaling)
    140 Posts 61 Posters 56.6k Views 61 Watching
    • fredo6F
      to ALL users,
      I made a small update (dated 28 Jan 09, 23:30 CET) to include some fixes of problems that were reported so far and also to include the Spanish translation (kindly provided by Pichuneke).
      You need to re-install both LibFredo6 and FreeScale
      • LibFredo6 3.0a --> http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16020#p124684
      • FreeScale 1.0a --> http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16021#p124685
        Daniel S
        Hi Fredo, I update to this new version.
        The first thing I try is a problem that I have in the previous version, but the problem is still there.
        I have some issues trying to scale about center (after press CTRL key).
        I attach a video showing what happens. Is like the center of the group is updated when you try to scale.
        Daniel S
        Scale about venter problem video .wmv
        • JClementsJ
          JClements
          Fredo:
          Is there anyway for you to add a "Check for Update" function in LibFredo6 ?
          It could check for an internal date or variable in the User's version of LibFredo6 and compare it to one on a server OR simply have it display a message which shows the most recent rev level with a link to a download page.
          I can see where LibFredo6 might be the "heart" of many important scripts and we'll (your loyal users) want to make sure its always kepT current.
          John
          • fredo6F
            Daniel,
            That's a bug, and actually quite subtle to fix. Thanks for signaling.
            Since you seem to know how to reproduce it, would you mind to try with the attached updated file.
            Again, many thanks
            to drop in subfolder FREESCALE_Dir_10
              Daniel S
              Yes, now works very well! thank you!. For me was easy to reproduce because it happened every time I tried to scale about center.
              Another problem that I have is when trying to scale Red, Green, Blue (all togheter) with a negative number.
              I attach a video showing this.
              In the video you will see that if I try to scale only red axis negative, only green negative or only blue negative all works well... but if I take a red blue and green grip to a negative number it turns crazy. The same happens if I press the ctrl key. It works well if I scale one axis only.
              Daniel S
              video of the problem .wmv
                Jim57
                Fred06— I can't thank you enough for this script. I've been begging for something like this, and it's so easy to use. I love the way it reads out in percentage and dimension, right on the screen where it's most visible. It's how the SU scale tool should have been done in the first place.
                Jim
                  jmmad
                  Thxs a lot Fred for this plugin, your ruby scripts are amazing.
                  Do you think you could add more transformations to it, like bend, twist, Bulge
                  Maibe for a comercial plugin?
                  Deform
                  Get Upa !
                  • fredo6F
                    [attachment=0:gebfklnj]<!-- ia0 -->Transforms.jpg<!-- ia0 -->[/attachment:gebfklnj]
                    I can add shear and twist without too much problem. But the royal way to all these deformations is definitely Sketchy FFD.
                    • K
                      kwistenbiebel
                      [attachment=0:3oyx96kl]<!-- ia0 -->Transforms.jpg<!-- ia0 -->[/attachment:3oyx96kl]
                      Please add it Fredo. 👍
                      I find your plugin to run more smoothly and controllable than FFD.
                      Shear and twist would be wonderful as a tool.
                      By the way, since I installed your plugin,I never use the default SU scaling tool anymore.
                      The plugin is fantastic and works very intuitive.
                      Thank you again.
                      • soloS
                        +1 for sheer and twist.
                          jmmad
                          I Know FFD is very powerful for deformation tool, but its not as fast and easy to use as your Taper Deformation Script.
                          with FFD it is very hard to do an accurate bend or twist, also you canot deform Nested Components or Grups, and you canot align the deformation as easy as you can do it with Taper deformation in your ruby.
                          Get Upa !
                            Daniel S
                            Fredo already post a shear transformation plugin that works very well.
                            Click here: PlaneShear
                            It`s not very popular because it´s inside a question topic.
                            Daniel S
                            • fredo6F
                              Daniel S
                              Daniel,
                              Another interesting bug (due to Sketchup precision reaching limits). I hope I hav fixed them (you had one for Taper with negative scales too)
                              Would you mind to try with this updated version.
                              Thanks very much
                              Fred
                              to drop in FREESCALE_Dir_10
                                jmmad
                                Daniel S
                                How could i missed a Fredo Script ?
                                OMG Shear works great Im impresed 2 times by you Fredo in a day, and nice icons you made last year for it Daniel.
                                Fredo the only thing i miss in shear deformation is that it groups the shear object at the end, in your Taper deformation that does not happen so you can deform part of an object without breaking it in 2.
                                It would be amazing to bend, twist, shear, bugle just part of an object.
                                That way Organic Modeling would be like playing with clay in SU,
                                Thxs to so talented scripters like you
                                Get Upa !
                                  Daniel S
                                  Fredo,
                                  This new version fixes all the problems in the scale tool in all the axis.
                                  I didn´t try before the Taper with negative scales. Seems that now there is a problem only if you try to Taper with negative scales about center (pressing the Ctrl key). All the rest works very well.
                                  I attach a video of this too.
                                  Thank you,
                                  Daniel S
                                  Taper with negative scales about center problem video .wmv
                                  • majidM
                                    majid
                                    just to sow my respect to u 😄
                                    majid
                                    • Y
                                      Yanman
                                      Fredo6
                                      Thank you! THANK YOU!!!very very VERY much Fredo6
                                      • H
                                        Heven7_floor
                                        Thanksyou Fredo ,it 's wonderful script, good idol of SU plugin for me ,I like it ,thanks again. 👍 👍 👍
                                          Rodentpete
                                          Great work with this very useful sript, Google really needs to give you a job!
                                          • FletchF
                                            Fletch
                                            I've been begging for this for years... and here it is...
                                            Fredo! You rock, my friend! Fantastic! Thanks so much for sharing!
                                            Fletch
                                            • 5 / 7
