    [Plugin] 1001bit Tools - Architectural tools for SketchUp
    243 Posts 65 Posters 247.8k Views 65 Watching
    • massimoM Offline
      massimo Moderator
      I've tried this toolset and after 10m i removed it. With 29$ you have a collection of plugins that you can get for free (and in many cases they work better) like align, Kt tools, trim and extend, fillet, roof, windowizer ecc. plus a duplicate of native SU commands like array, offset ecc. Maybe i missed something...
        you miss revolve, extrusion along a path,...etc and all pre-build parametrics elements ๐Ÿ˜‰
        • images help inside ๐Ÿ˜‰
          Plus it's neatly packaged with a uniform UI and continuously maintained.
          • massimoM Offline
            massimo Moderator
            Ok, thanks. I'll give it another try.
            • G Offline
              gohch
              hi everyone!
              Thanks to Charles Tom of http://www.geoinfo.com.tw there's now a language pack for
              1001bit tools in Chinese Traditional็น้ซ”ไธญๆ–‡
              http://www.1001bit.com/language_pack/v1.1/ct/1001bit(v1.1.6)_ct_geoinfo.zip
              Thanks Charles for your support and sharing!:)
              • aadbuildA Offline
                aadbuild
                1001 bit is definately a big time saver when modeling. I have done some great animations and client think they took me weeks where they only realy took hours. The rafters, battens and hips are fantastic
                Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                https://www.plusspec.com
                • G Offline
                  gohch
                  Thanks aadbuild for your support!
                  Have been a bit tight on time working on a shadow analysis tool (in collaboration with Takeshi)
                  see http://www.1001shadows.com
                  Hope to get back to 1001bit tools by next month.
                  cheers!
                  Goh
                    CrackerJim
                    I've downloaded the 1001bit tools and also downloaded the help file from their forum. When I open it, it appears to open in a reader application. The table of contents appears on the left pane but regardless of what I click in the left pane, nothing but invalid address message appears in the reading pane.....
                    any suggestions?
                    Thanks for any help,
                    Jim
                    • G Offline
                      gohch
                      ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„ Merry Christmas Everyone!!! ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                      1001bit version 1.1.7 update is now ready for download!
                      http://www.1001bit.com/v1.1/download_registration_v1.1.shtml
                      3 new tools are added into this update:
                      Rectangular grille tools: convert edges into rectangular sections.
                      http://www.1001bit.com/forum_imgs/rgrille1.jpg
                      http://www.1001bit.com/forum_imgs/rgrille2.jpg
                      Circular grille tools: convert edges into circular sections.
                      http://www.1001bit.com/forum_imgs/cgrille1.jpg
                      http://www.1001bit.com/forum_imgs/cgrille2.jpg
                      both the grille tools only create grilles on a common plane defined by the first 3 points it finds from the selection.
                      any edges that are not on the plane will be projected onto the plane.
                      Extrude while maintaining tapering effect.
                      http://www.1001bit.com/forum_imgs/extrude2.jpg
                      ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„ Wishing everyone a very Happy Christmas, and all the best in the coming year! ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„ ๐Ÿ˜„
                        Thanks Goh for the update! this whole toolset seems to be very useful not only for architects actually! ๐Ÿ‘
                        I have also "updated" The Daily CatchUp.
                        Also, if you don't mind, I have renamed the subject of the topic to
                        [Plugin 1001bit Tools - Architectural tools for SketchUp]
                        and moved it into our new Plugins forum. This seems to be more straightforward for this topic as it is a discussion between developer and users rather than about ruby methods (or what) between developers.
                        • G Offline
                          gohch
                          Thanks Gaieus,
                          Agree, Plugins forum is closer to the nature of this forum. ๐Ÿ˜„
                          Cheers everyone, and Happy New Year!! ๐Ÿ˜„ ๐Ÿ˜„
                            lrarquitetura
                            Ola!
                            posso baixar este plugin?
                            Obrigado
                              Oi Luis,
                              Vocรช pode baixar o plugin em seu site:
                              • N Offline
                                nektares
                                404 dude u_u
                                  @nektares said:
                                  404 dude u_u
                                  โ“
                                    AcesHigh
                                    @gaieus said:
                                    Oi Luis,
                                    why are you speaking portuguese? (por que tu estรก falando portuguรชs?) ๐Ÿ˜„
                                      Because he asked in Portuguese. ๐Ÿ˜’
                                      A forum admin needs to speak all languages.
                                      ๐Ÿ˜„
                                      • BurkhardB Offline
                                        Burkhard
                                        ๐Ÿ˜„
                                        Bah to tongoo des lamedatro turi, Gaius
                                        bena sa tola ๐Ÿคฃ
                                        http://www.ia-plus.de
                                        • aadbuildA Offline
                                          aadbuild
                                          Now your just showing off Gaieus. ๐Ÿ˜Ž
                                          have a great new year all
                                          or as some would say in Australia.
                                          Have a bloody ripper, crack a few tinnies over a barby while your at it mate.
                                          • bagateloB Offline
                                            bagatelo
                                            GOHCH
                                            Your plugin is fantastic, really very useful.
                                            I work with Sketchup the day complete, drawing projects of pieces of furniture and interiors.
                                            Please, consider the possibility to create some tools that help in the development of pieces of furniture. Please, visit my site to see some of my work:
                                            http://cg-alex.blogspot.com/
                                            I think about something can create furniture like Chief Architect:
                                            http://www.chiefarchitect.com/products/features.html
                                            If it was possible to edit the generated blocks, something as the technology BIM, would be very cool. PLease consider the operation of REVIT:
                                            http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=8479263
                                            Please, consider some alterations that I have been doing in a plugin:
                                            http://forums.sketchucation.com/viewtopic.php?f=180&t=24426&p=211719#p211719
                                            Thanks anyway.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 8 / 13
