    Making Surfaces to Pull
    8 Posts 5 Posters 1.2k Views 5 Watching
    • J
      Jim57
      I'm modeling a bench. Using the BezierCurve Ruby, I've made some curves, connected with straight lines, to outline the end. Now I want to pull the outline into a block to make the actual end. However, there's no surface to grab hold of to pull.
      I've zoomed in as best I can and the joints between line segments all seem to meet (after a point, the zoom goes through the lines & I can't look any closer).
      I checked for flatness by filling it in with triangles, which each made a plane surface, then erasing the divisions between them. The plane surface held, meaning the curves are flat and everything is planar.
      What else can I do to force a plane surface? Anything short of outlining each curve point by point?
      Thanks,
      Jim
      Pew End.skp
      • thomthomT
        Could be a hidden line across your face. SU will then refuse to push/pull that face since it's really two faces. (or more)
        You can use the plugin Join Push/Pull to push/pull multiple faces.
        • GaieusG
          Hi Jim,
          That profile is a group. Double click on it to edit the find two neighbouring endpoints which if you connect with a line, the flat side will heal.
          Still inside the group, you can P/P it without any problem.
          • honoluludesktopH
            honoluludesktop
            Gaieus, I had to zoom way in to connect the points as my line would snap to some reference point. Is there a way to only snap to the end point?
            • GaieusG
              I had to zoom in,too (well, it's a bit poly heavy as it's made of beziers). Unfortunately there's no way you can get rid of certain inferences although sometimes it would be very handy.
              • C
                cosycat
                Not sure if this is what you want, but a trick I picked up (from here ?) is to draw a rectangle around the shape then delete the unwanted bits - you'll have top ungroup your lines first
                Pew End2.skp
                • J
                  Jim57
                  I checked about 6 times and could not find a gap. Finally I tried looking for endpoints with the Line tool. Still didn't find a gap, but when I reconnected any two segments of the outline it filled in.
                  Damn, it's always the simple stuff.
                  Thanks, Gai!
                  • GaieusG
                    It's because I can only find the simple solutions. πŸ˜‰
