    Can't find the internet
    4 Posts 4 Posters 644 Views 4 Watching
    • H Offline
      haggis2
      When I am using my sketchup and try to find components or 3d warehouse, it says it can't find the internet. My internet is working, just Sketchup can't find it. What am I doing wrong?
        Hi William,
        I this happening when making a component or when saving it as an external skp file?
          @haggis2 said:
          When I select a something like a window and then ask it to be saved as a component in the Edit window, when I go to window component, it is not there. There are other things, but the thing I created is not there. What am I doing worng???
          Are you saving it as a component within the model or exporting it ?
          If it's within the model then the component browser should show it up in the 'model' tab (little house)
          If you want that saved externally then right-click over it and 'save_a' to a desired folder.
          If you've saved it externally into you SUp Components folder then perhaps you are on Vista without Admin rights and the system has shunted them into a compatibility sub-folder ?
          • P Offline
            peweuk
            I found this an unexpected Vista issue with SU for components and templates, but I think from his profile he is using XP which should not be an issue (providing he has not setup different user accounts with different permissions).
            I wonder if he is using the 'save as' in the component browser to save it to his own directory outside of the SU Components folder (in program files), and is not then either moving the directory into the SU components directory, or not loading it as an external library.
