    Profile Builder released!
    125 Posts 41 Posters 60.9k Views 41 Watching
      Would it be possible to make the script set focus to the SU window after you click the Build tool button? I find that I often want to start at a location on another profile's path, but in order to do that I need to enable the PMPI. When I click the build button I have to first set focus to the SU window before I can begin. It's something that I do often so it'd be very nice if the plugin would do this automatically.
      Also: Hotkeys for each of the buttons in the PB window? Pleeeease? I'm a hotkey addict.
      • utilerU Offline
        utiler
        Thomas, why don't you make your own hotkeys to suit?
        Just Curious...
          I can't. When you go to the SU preferences for hotkeys it doesn't the commands. 😞
          And I did mean that I wanted to be able to set my own and not hard coded hotkeys. Might not been clear.
          • david_hD Offline
            david_h
            but I think Whaat has covered all this in his superb manual
            You mean I have to read something? πŸ’š
            Thanks for the input!
            • david_hD Offline
              david_h
              here's another little glitch i am running into . . .I trace a path for a door casing and it seems to follow the path fine, but then when I finish the command. .there's nothing there!
              Whaddup???
                You're not drawing onto a hidden layer?
                • david_hD Offline
                  david_h
                  Nope. that was the first thing I checked for. I Draw exlusively on layer 0, so that typically is not a problem. I am going to try a restart of the program, cuz when I just doodled in a test file, it worked fine, but in my work model. .. nuthin'.
                  D
                  • W Offline
                    Whaat
                    Whaddup???
                    Is this repeatable? Are you using SU6 or SU7? Any error messages in the Ruby Console? Check your outliner window to see if the member was created.
                    • utilerU Offline
                      utiler
                      Dale and All,
                      I am building a library of AU specific profiles for UB's, UC's, PFC's, EA's, UA's, RHS, SHS, CHS, etc, etc..
                      Dale, I noticed you built the basic profile without the radius on edge. I am building the library with a 3 to 6 sided curve to depict the real thing.
                      Also, for RHS, CHS, SHS profiles I was only going to create the external profile, not inclduing wall thicknesses. [in some cases steel thicknesses are 1.6mm]
                      Any thoughts either way?
                      When I'm done, I'll let you know and PM me if you'd like me to email you the libraries.... πŸ‘
                      Just Curious...
                      • W Offline
                        Whaat
                        @utiler said:
                        Dale and All,
                        Well, I had intended to provide a AU steel library at some point. It is not difficult for me to do it. If you have a spreadsheet of the section properties I could save you the trouble. Real-world accuracy is very important so please double-check your dimensions before submitting the library.
                        Thanks but I can't directly use a profile that is not composed of a solid face. 1-D profiles may never be supported by PB. I haven't decided yet.
                        Thanks!
                        • utilerU Offline
                          utiler
                          I actually jumped the gun last night Dale and got into it!!! I have compiled UB's, UC's and PFC's so far. Yes, I have section properties of actual sizes and have diligent in creating actual real world sizes. [some webs and flange sizes needed to be rounded up or down to the nearest millimeter; I don't think 0.5mm will be a drama!!]
                          Thanks!
                          Sorry, I didn't make myself clear. I mean the CHS profile from the face created by the outside diameter, not the 1.6mm - 6.0mm thickness of the member. Obviously, just trying to cut down on faces....
                          Just Curious...
                          • W Offline
                            Whaat
                            Phil Rader has graciously created a profile library of concrete curbs. It is now available on the Smustard website: http://www.smustard.com/script/ProfileBuilder. Thanks so much Phil! I welcome any others who wish to share their library files. If you are interested, you can send it to the email address at the bottom of the Smustard site.
                              @jclements said:
                              Dale:
                              Question: Were closed paths supposed to meld at their start/end vertex? I see some other folks have noted this but I didn't see a response.
                              They are supposed. But they don't always. I find that it's more likely they'll connect if the position point is a point on the profile path. And instead of connecting the start and end at a corner I start somewhere on a straight path.
                              • JClementsJ Offline
                                JClements
                                Dale:
                                Pretty darn neat.
                                [Question: Were closed paths supposed to meld at their start/end vertex? for example, draw an rectangle and delete its surface and use it as a path. [Edit.] However, when I draw an edge which intersects and breaks one of the rectangle's side, then a continuous rectangular extrusion is formed. [End Edit.] I see some other folks have noted this but I didn't see a response.
                                [Question: I also discovered that if my original path was "welded", the script exploded the copy it created. Would there be a way to test if the path is welded or an arc or a circle, then restored that attribute to the copy?
                                John
                                • E Offline
                                  Ecuadorian
                                  There are less and less reasons for using ArchiCAD nowadays...
                                  -Miguel Lescano
                                    jonorman
                                    REQ question..
                                    would it be possible to add properties to the profile ?? a.iI have a aluminum profile then i could add the aluminium name AL8365 and the weight of the material. out of this i have what i need to get the weight rapport of the structure.
                                    lenght x volume x weight = kg/m
                                    i can do this now by using the rapport but i have to do the math, but i wonder if this could be integrated ???
                                    thnx for a great plugin.
                                      Jorgensen
                                      Would be nice with a fillet and trim / extend function πŸ˜›
                                      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
                                      • utilerU Offline
                                        utiler
                                        Hi all,
                                        I have finally had a chance to finish the Australian Steel profiles which I have email to Dale for inclusion on the smustard website for download. Included are all sizes available to the Australian market in: [actual section properties]
                                        Universal beams
                                        Universal Columns
                                        Equal Angles
                                        Unequal angles
                                        Parallel Flange Beams
                                        Circular Hollow Sections
                                        Rectangular Hollow Sections
                                        Square Hollow Sections
                                        Let me know if any issues....
                                        πŸ‘
                                        Just Curious...
                                        • W Offline
                                          Whaat
                                          Great! Thanks! I will add these to the website.
                                            dtrarch
                                            Dale
                                            Just another request for visual viewer/editor for shape libraries please.
                                            With the expanding scope of shape libraries it would be a big help to be able
                                            to select the most used profiles and make ones own group without having to scroll through the menu and pick and choose.
                                            Just a shape source in SU or equal would do the job.
                                            Maybe thumbnails like in xnView.
                                            dtr
                                            • 6
                                            • 7
                                            • 3 / 7
