    Profile Builder released!
    125 Posts 41 Posters 71.5k Views 41 Watching
    • david_hD Offline
      david_h
      but I think Whaat has covered all this in his superb manual
      You mean I have to read something? πŸ’š
      Thanks for the input!
      • david_hD Offline
        david_h
        here's another little glitch i am running into . . .I trace a path for a door casing and it seems to follow the path fine, but then when I finish the command. .there's nothing there!
        Whaddup???
          You're not drawing onto a hidden layer?
          • david_hD Offline
            david_h
            Nope. that was the first thing I checked for. I Draw exlusively on layer 0, so that typically is not a problem. I am going to try a restart of the program, cuz when I just doodled in a test file, it worked fine, but in my work model. .. nuthin'.
            D
            • W Offline
              Whaat
              Whaddup???
              Is this repeatable? Are you using SU6 or SU7? Any error messages in the Ruby Console? Check your outliner window to see if the member was created.
              • utilerU Offline
                utiler
                Dale and All,
                I am building a library of AU specific profiles for UB's, UC's, PFC's, EA's, UA's, RHS, SHS, CHS, etc, etc..
                Dale, I noticed you built the basic profile without the radius on edge. I am building the library with a 3 to 6 sided curve to depict the real thing.
                Also, for RHS, CHS, SHS profiles I was only going to create the external profile, not inclduing wall thicknesses. [in some cases steel thicknesses are 1.6mm]
                Any thoughts either way?
                When I'm done, I'll let you know and PM me if you'd like me to email you the libraries.... πŸ‘
                Just Curious...
                • W Offline
                  Whaat
                  @utiler said:
                  Dale and All,
                  Well, I had intended to provide a AU steel library at some point. It is not difficult for me to do it. If you have a spreadsheet of the section properties I could save you the trouble. Real-world accuracy is very important so please double-check your dimensions before submitting the library.
                  Thanks but I can't directly use a profile that is not composed of a solid face. 1-D profiles may never be supported by PB. I haven't decided yet.
                  • utilerU Offline
                    utiler
                    I actually jumped the gun last night Dale and got into it!!! I have compiled UB's, UC's and PFC's so far. Yes, I have section properties of actual sizes and have diligent in creating actual real world sizes. [some webs and flange sizes needed to be rounded up or down to the nearest millimeter; I don't think 0.5mm will be a drama!!]
                    Sorry, I didn't make myself clear. I mean the CHS profile from the face created by the outside diameter, not the 1.6mm - 6.0mm thickness of the member. Obviously, just trying to cut down on faces....
                    Just Curious...
                    • W Offline
                      Whaat
                      Phil Rader has graciously created a profile library of concrete curbs. It is now available on the Smustard website: http://www.smustard.com/script/ProfileBuilder. Thanks so much Phil! I welcome any others who wish to share their library files. If you are interested, you can send it to the email address at the bottom of the Smustard site.
                        @jclements said:
                        Dale:
                        Question: Were closed paths supposed to meld at their start/end vertex? I see some other folks have noted this but I didn't see a response.
                        They are supposed. But they don't always. I find that it's more likely they'll connect if the position point is a point on the profile path. And instead of connecting the start and end at a corner I start somewhere on a straight path.
                        • JClementsJ Offline
                          JClements
                          Dale:
                          Pretty darn neat.
                          [Question: Were closed paths supposed to meld at their start/end vertex? for example, draw an rectangle and delete its surface and use it as a path. [Edit.] However, when I draw an edge which intersects and breaks one of the rectangle's side, then a continuous rectangular extrusion is formed. [End Edit.] I see some other folks have noted this but I didn't see a response.
                          [Question: I also discovered that if my original path was "welded", the script exploded the copy it created. Would there be a way to test if the path is welded or an arc or a circle, then restored that attribute to the copy?
                          John
                          • E Offline
                            Ecuadorian
                            There are less and less reasons for using ArchiCAD nowadays...
                            -Miguel Lescano
                              jonorman
                              REQ question..
                              would it be possible to add properties to the profile ?? a.iI have a aluminum profile then i could add the aluminium name AL8365 and the weight of the material. out of this i have what i need to get the weight rapport of the structure.
                              lenght x volume x weight = kg/m
                              i can do this now by using the rapport but i have to do the math, but i wonder if this could be integrated ???
                              thnx for a great plugin.
                                Jorgensen
                                Would be nice with a fillet and trim / extend function πŸ˜›
                                • utilerU Offline
                                  utiler
                                  Hi all,
                                  I have finally had a chance to finish the Australian Steel profiles which I have email to Dale for inclusion on the smustard website for download. Included are all sizes available to the Australian market in: [actual section properties]
                                  Universal beams
                                  Universal Columns
                                  Equal Angles
                                  Unequal angles
                                  Parallel Flange Beams
                                  Circular Hollow Sections
                                  Rectangular Hollow Sections
                                  Square Hollow Sections
                                  Let me know if any issues....
                                  πŸ‘
                                  Just Curious...
                                  • W Offline
                                    Whaat
                                    Great! Thanks! I will add these to the website.
                                      dtrarch
                                      Dale
                                      Just another request for visual viewer/editor for shape libraries please.
                                      With the expanding scope of shape libraries it would be a big help to be able
                                      to select the most used profiles and make ones own group without having to scroll through the menu and pick and choose.
                                      Just a shape source in SU or equal would do the job.
                                      Maybe thumbnails like in xnView.
                                      dtr
                                      • W Offline
                                        Whaat
                                        @dtrarch said:
                                        Dale
                                        dtr
                                        Yes, I know, you have requested this about 10 times now... πŸ˜‰ I would gladly add it but it is not trivial. In fact it would take many months to implement and I do not have the time to work on that right now. I have some ideas to improve the browsing of Profiles but this a LONG way off from even being worked on yet. I do appreciate the suggestions, though. I am not trying to ignore you here. This really is a big task and I still don't know if the amount of work that it would take is justified.
                                        • utilerU Offline
                                          utiler
                                          One other idea Dale,
                                          Have you thought about the option of an 'end cap' to profiles? It could be a tick option in the dialuge box to cap start and or end of the profile.....
                                          Just a thought.
                                          Just Curious...
                                            dtrarch
                                            Hi Dale
                                            Many thanks for the reply and explaining the difficulty in developing a library reader or editor.
                                            Apologies for chewing on you leg on this and I will go directly to Smustard and get a proper copy of this killer app just to keep things even.
                                            Regards
                                            dtr
                                            • 3 / 7
